Question about Mackie SWA1801 Subwoofer
MACKIE SWA1801--Sound quality is not same
Hello! About 4 years ago I bought one MACKIE SWA1801 subwoofer in Hungary and 2 years ago I also bought a same sobwoofer from Austria. The problem is: the new one can not working well. If I push up the fader on the mixer the woofer can be make a distorsion but the PEAK LED is not light. And the older subwoofer is working well parallel. I re-assembled the woofers from the wooden boxes. The older woofer was made by RCF the new was made by Eminence. I went to the speaker enginner. (He has 15 years experiance in the woofer world). He said the Eminence woofer is working Ok. The membrane and the coil is not damaged. It seems everithings are OK. I made cross test. I mean I put the Emience woofer in the onother box with the older amplifier. The result is same. The woofer is working well on a little volume but if I push the fader to get a bigger sound the woofer is distorted. I am really sad now because I can not hear my loudspeakers in same volume level. I have to reduce the volume of the right What can I do? Would be buy a RCF woofer to get a same sound quality? I hope you understand my problem. I waiting for your reply! Bye and thanks in advance!
  • Peter Szoke Nov 07, 2007
    I will try and chek it!
  • Anonymous Dec 21, 2007
Also had the same problem excepts the membrane on eminence was toren out but the coil was fine. Solution ,buy RCF G400 that is the sub in the original-first 1801s
Posted on Nov 30, 2009
Fanculo zuzu
Posted on Aug 27, 2008
First, Try the "defective" woofer in the cabinet that works well to be sure the woofer is OK.
If the woofer sounds good in the other cab, look to the power amplifier board : you have to test 2 fuses and 2 transistors witch are connected to the fuses : a defective transistor let your subwoofer work fine to half power, but distortion appear if you push away...
Posted on Oct 27, 2007
I suggest, go out and buy a heavier duty 18 and replace it.
Posted on Sep 28, 2007
Both my 1801s gone over xmas..fuse at bottom of board popped when swiched on, replaced fuse but no sound now although LEDs are on?
Fuses blow because of an overload. In this case it will be a shorted semi-conductor. Most likely in the main amp section. Maybe the main amp itself. It might be attached to a heatsink.
Jan 24, 2013 | Mackie SWA1801 Subwoofer
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
Can you tell me what the impedance is of the SWA 1801 speaker?
As per spec sheet states:
Input Impedance = 50K for the Active System
SWA1801 Active Subwoofer Spec Sheet - Mackie
For the passive speaker =4 ohms
Sep 14, 2011 | Mackie SWA1801 Subwoofer
No power
There are about 6 fuses on the inside. check them but the amp is probably blown
May 26, 2011 | Mackie SWA1801 Subwoofer
I have damaged the cone on my swa 1801z subwoofer can I get a replacement cone and where ?
  • Yes you can. It is not the easiest of tasks but far cheaper than replacing that 18. There are a few places you can get recone kits from so I will list a few of them and let you decide the quality of kit you wish to purchase.
  • Here is a place that will recone all moving parts for you. Of course there is some shipping involved.
Regards, Tony
Apr 25, 2011 | Mackie SWA1801 Subwoofer
The thermal light comes on on my swa1801 and lose all audio what could be causing this to happen?
make sure its plugged into a large circuit over 30AMP! Turn down the gain on the back. They can't take too much punishment so turn the bass down on the eq. Get a stronger sub
Jul 01, 2010 | Mackie SWA1801 Subwoofer
How do you get to the ac fuse on the SWA1801 ?
There are 4 allen-head screws that hold the amplifier assembly in - two on top and two on bottom. Remove these and the entire thing slides out the back. There is one fuse near the power switch and two on the power supply board inside. Be sure to use the correct value.
May 13, 2010 | Mackie SWA1801 Subwoofer
Ould some one send me a copy of that schematic. I
Sorry, not really a solution yet. Just contacted the Belgium Service center. They say they're not allowed to give the schematics. Maybe Mackie is ashamed to show what's in it? Any way, this is all but a good publicity for the service of Mackie
Gerdy's Music Shop
Nov 07, 2009 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
794 people viewed this question
Top Mackie Audio Players & Recorders Experts
Vito Vacirca Jr.
Shehu Pro
Shehu Pro
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
