JMB 32in flat screen television volume, works for ten min's then tuns itself off. I have tried every thing I can think of and done evrything in the instruction booklet. Yet nothing as yet has worked. Ideas would be great Thank you.
If it works about 10 minutes and shuts down gradually, the fault must be with its audio output IC. Replace it.
Testimonial: "It doesn't shut down gradually,it sounds like a click then just goes silent. It really has me stumped as everything else works!! Gr "
SOURCE: Connecting Television to Computer
does the tv have an hdmi, fpc or vga connector? these are the prefered inputs from a PC.
SOURCE: I have a Olivia television flat screen. after a
If u have no power lites lit up on the tv, then it may just be a blown fuse. if not then the power supply board would need repairs. should be taken to a shop
SOURCE: ILO 26HD television flat screen won't change channels/stuck on 11
Try doing a channel scan or autoprogram of the tuner again. This should fix the issue.
