On my other TV in the next room (just inches away) I can get about 15 OTA channels perfectly, but using the same antenna, no matter where I put it, I can't seem to get any channels on the hisense. I was thinking maybe I just need to get a separate receiver, but it's a relatively new TV (bought around 2011). Before i go out and buy a receiver, are there any thoughts on what the problem/solution is? Thanks.
SOURCE: Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
SOURCE: I cannot get any TV channels on my Sony TV
It sounds like you have identified the the correct problem, as the Coax connector has probably been knocked loose from the circuit board inside the TV. If you have any knowledge on this sort of thing you can take it apart and re solder the connections. If not I suggest you take it to be serviced by a professional.
SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
