Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Water in bottom of dishwasher
Similar to an earlier post I have a dishwasher that also accumulates water in the bottom between washes. However, the water in the bottom of the dishwasher is not new/clean water. Rather it is dirty water that must come from the sink. Problem?
  • Anonymous Mar 17, 2014
    clean water accumulating in bottom of dishwasher when not in use
  • 725 Answers
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Posted on Aug 25, 2007
SOURCE:
Sediment is collecting in the bottom and on the dishes. I have tried a cleaning cycle but it doesn't work.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Maytag 24 in. MDBH750AWS Stainless Steel...
The dishes have a gritty residue on them after the wash cycle is complete.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jul 02, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher is not cleaning the dishes. Both on full service wash and 1 hour wash.
Jun 18, 2011 | Kenmore Dishwashers
The glasses are really really cloudy. I cleaned the bottom and filled the jetdry area. Didn't fix the problem. What should I do now?
Apr 04, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishes are not getting clean
Mar 21, 2011 | Frigidaire PLD4375RFC Dishwasher
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Dishes not washing very well
Dec 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
1,270 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
