Question about NEC MultiSync MT1050 Multimedia Projector
Projector starts then shuts down with status light flashing
Fan dosnt run at all have changed lamp and still does the same lamp lights then goes off and staus light flashes 3 times then stays on and so on
    Sergeant:
  • 261 Answers
Possibly the power supply could be bad or also known as the ballast. But keep in mind that there is a little switch for safety reasons near the cover you are taking off to change the lamp that could not be reactivated causing you the same symptom as a bad lamp. Make sure the switch is closed. than recheck. OR possibly you could have received a bad lamp. I have seen that happen on occasion. Keep me posted. Thanks Jay
Posted on Jan 31, 2008
SOURCE:
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Nec lt81 dlp projector
PLEASE SEE THE SPECS OF OLD LAMP AND NEW ONCE ARE THE SAME IF YES TRY CHECK THE POWER SUPPLY AND RATING OF THE SUPPLY. AND RESET SWITCH WITH REMOTE CONTROL
Feb 24, 2008 | NEC MultiSync MT1050 Multimedia Projector
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
New bulb worked for a short trail run now wont light up. flashing green led colour wheel is turning on start up
when you changed the lamp, did you blow the dust out of the projector? if the screen on the side of the lamp is blocked (i.e. with dust), the lamp will blow quickly. if the projector were to overheat, by the fans not running or blocked vents, everything would shut down and the led would blink red.
Jan 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
NEC MultiSync MT1050 Multimedia Projector Logo
296 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
