Question about StompSoft BackUp My PC 2005 (05004) for PC
'cannot access program - in use by another user or process'
Have to reboot to be able to access program
    Sergeant:
  • 457 Answers
I know it may be a bit tedious at times but try an uninstall the programme and then reinstall it. Backup my PC seems like a good programme but you know what Windows Live have a programme in their "One Care" Antivirus solution programme. Its called one care solution and does a clone of your entire HD and it copies everything and took 6 minutes to do a 80G I couldnt believe it those brainey MIcrosofters......wicked
Posted on Sep 02, 2007
6ya staff
SOURCE:
When i use it goes to blue screen
Is it rebooting ?
you might not have enough computer ram installed putting to much strain on the cpu or to many other programs accessing the internet at the same time
Scroll to bottom toolbar (bottom of screen) right click select task manager applications and processes to see you whats running and ticking over if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be running select end now and users you will see who is using your computer
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Feb 13, 2013 | Computers & Internet
Tip
Installing Devices on PCs and Laptops
Although there is a wizard to install devices on your PC or laptop, but still there are problems being faced by users. The reason is that there is a logical procedure for installations. Read on.
There are two things that you install. The drivers for all the devices and the program to use that device for some. First of all insert the CD that came with the device into the CD drive and let Autorun takeover. You will be guided throughout the process. Just answer a few questions and the SW will start the installation process for drivers. Once drivers have been installed then you can proceed with the installation of the program needed to run the device, not for all devices. After this task is accomplished always reboot the computer/laptop.
After the reboot, attach the device to the PC. Windows will immediately start the detection process and on detection will load its drivers that you had just installed. And then a notice appears in the right bottom corner of the screen saying "The new hardware was successfully installed and is ready for use". Or words to that effect. Now you can start using the new device whether through its specific program or through other programs that are meant to use it.
There are times when you are reinstalling the drivers. In that case you must first uninstall the old drivers and reboot the PC/laptop. Uninstall it from Control Panel->Add Remove Programs. And then reboot and reinstall.
on Dec 02, 2009 | Computers & Internet
I recently downloaded myscribe to access an ebook for school. Once the program downloaded my ebook appeared but when i went to open it I recieve an error message and the program closes. My class starts...
Either the book or the program is corrupted. Start by reinstalling the program: uninstall what you have now, manually delete every remaining file and folder (do a search for all of them) then reboot the pc. Now download the installer again (as in Save, not Run) from here
http://downloads.cafescribe.com/MyScribeSetup.exe
Once the download has ended close the browser, open Computer and create in Programs a new folder called Books. Next launch the installer - during the process you will be asked where to install, select the Books folder you have just created. Wait for the install process to finish then reboot again.
Now copy the ebook in the pc and try to open it with the newly installed program - if it fails again then the book file is corrupted and you will have to redownload it from the school's server - or from where you got it the first time.
Jul 03, 2011 | Computers & Internet
Says warming up but then get scanner failure message
Friend, You need to reinstall the device as the scanner portion of the drivers are malfunctioning. Please read the following and act accordingly:
Apr 20, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
My defrag program says it is unable to gain access to selected drive. It says another process may have the drive locked???
you need to close all open programs and reboot before you defrag
if you want a clean reboot go to start remove all programs from the startup file so nothing is in the background, if McAfee is in your start up file, it will prevent you from a complete defrag
start/all programs/startup click and drag each file in the startup back to all programs and then do a new reboot
May 11, 2009 | Computers & Internet
Company file in use message when several users access the file
If this is a real time program changes should be able to be made simutaniously. Check with your IT department, they may have to increase the allowed user #. If your position is top priority, some programs will allow more than one "super user" profile, the "super user" can make changes at anytime, but that profile is subject to corporate approval.
Apr 23, 2009 | Intuit QuickBooks Premier 2008 (3-User...
Access problem
see if the LDB file still exist and delete it...
Whenever you open an Access database, a file with the same name as the database and an extension of LDB will be opened automatically. For example if you open Northwind.mdb in the samples directory of your Access/Office installation, a file called Northwind.ldb will be generated. This new file keeps track of users and the objects that require some form of locking in the database. When all users have exited gracefully from the database, the LDB file is closed down and deleted.
thanks for rating
Jan 09, 2008 | Microsoft Office Access 2003 (077-02871)...
Update record with two table
have an Access 2003 database that appears to be very corrupt.
I was having a problem and did a compact and repair on it, and I
lost my network connection during the process. Now when I try
to open it (or access it via DTS, VB, anything I can think of),
I get
"The Microsoft Jet database engine stopped the process because
you and another user are attempting to change the same data at
the same time".
I have rebooted the machine that was accessing it, and no
help. I can't reboot the server now because it's a 24/7 file
server. Is there any way to get this database open? I have
searched and found a bunch of demo programs that will
"uncorrupt" it and show some data (but not save it), so I know
it's possible, but is it possible without buying one of those
programs?
thanks
Jan 08, 2008 | Microsoft Office Access 2003 (077-02871)...
StompSoft BackUp My PC 2005 (05004) for PC Logo
59 people viewed this question
Top StompSoft Computers & Internet Experts
Tom Chichester
Joseph Wright
ELECTRICKSUSA
ELECTRICKSUSA
Are you a StompSoft Computer and Internet Expert? Answer questions, earn points and help others
