Question about Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Keyboard bug When I press the characters ´ and ~ they show up duplicated. Like this ´´ and ~~. This only happens whith this two buttons. Even when the shift is on. ´´``~~^^, see?
    Brigadier General:
  • 6,966 Answers
Hi, Typical keyboard problems such as this can be attributed to dust and other foreign material that get lodged in between the contact switch of each key. Since the repair cost sometimes exceed the cost of a new keyboard, it may be to your advantage to simply purchase a replacement (that is of course if the errors outweighs the use). A trick you can try is lengthen the time between repetitive keystrokes (but this will apply to all the keys not only ' and ~). This is done in your BIOS (assuming this feature is available with your motherboard). On powerup, press del or the key designed to enter the BIOS setup. See if you have the option to control your "Typematic Rate Setting" and select enable, in the "Typematic Delay:, select 500 or higher. Save and reboot. Hope this works for you. Good luck and kind regards.
Posted on Aug 24, 2007
SOURCE:
I have a TE-2000 cash register and find the instruction manual very complicated. Could you please advise on how to programme a logo message, commercial message and bottom message. Thanks in advance.
Turn your key to PGM enter 2 subtotal enter 0132 and press subtotal now you enter your 21 or 24 characters for the first line and press CA or the lower right hand button. Now enter 0232 and press subtotal and again enter characters and press CA or the lower right hand button.
Follow this for 4 lines and when all done press Subtotal.
I believe the register you have will show you the characters on the keyboard and just use those to make your logo.
Oct 19, 2009 | Casio Parts Cash Register PC Desktop
I get a keyboard character repeating accross the page even when i am not writing
try checking your keyboard if some characters are pressed. The reason here is that, maybe you pressed it too hard last time you used it. Making one of the characters you pressed stuck. It is advised to check it.
Aug 10, 2009 | Computers & Internet
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
Apr 23, 2009 | Dell 0Y3740 Keyboard
I,j,k,l showing numbers
Have you tried the Num Lock button?
Apr 05, 2009 | Gateway MT3705 Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Car cd player code breaker
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Nov 09, 2008 | Kenwood KDC-MP528 CD Player
Help
for your kdc-mp332 type 2 below will work whith code KCAR entered from the remote
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Sep 09, 2008 | Kenwood KDC-MP332 CD Player
Trying to get the code to a kdc332
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
UNLOCK SECURITY CODE
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Jul 09, 2008 | Kenwood KDC-MP528 CD Player
Open Questions:
See all Microsoft Basic Keyboard 1.0A PS/2 KEMIBA Questions
Computers & Internet Logo
300 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
