Question about Canon LBP 1120 Laser Printer
Pause/printer rest between pages
We have this printer at work and we use it to print receipts and certificates for the surgery. It pauses/rests inbetween every page, it literally stops everything and then starts up again for each page! So printing multiple pages takes FOREVER!! how do I change the settings to prevent this pause? Any help will be HUGELY appreciated :) Cheers Lainey
    Brigadier General:
  • 6,966 Answers
Hi nurse_boop (Lainey), You can try changing some of the printer settings. Assuming you're using Windows, go to Start, Printers and Faxes, and right click on your printer, choose Properties: 1. Make sure that you disable printer pooling; 2. Check/tick, print directly to the printer; 3. Check/tick, Printer is Always Available. Please keep in mind that large file sizes, images and deep colors adds to the slowdown and pauses of printers. Hardware wise, large documents requires more memory both on the printer server PC and the printer itself. Hope this be of some help to you. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
  • Louie  Role
    Louie Role Aug 25, 2007
    Hi again,
    If your printer is USB connected, you may want to check if it is 2.0 and not 1.0, big difference in speed.
    Cheers.
How I print a config sheet
To print the test page hold the pause button of printer and on the printer. dont leave pause button till the printing .
Sep 25, 2014 | Epson TM-U325D-940 DOT MATRIX RECEIPT &...
Mfc 7340 pause
when we pause some prints from specific computer (if ur using lan) then go to computer where physically printer attached then print some pages and when printer utility display appears on screen find on that pause is enable trying to resume from that
May 04, 2012 | Office Equipment & Supplies
How to printer test page from the display panel zebra zm600
With most Zebra printers, a test page is printed by pressing and holding the PAUSE key while turning on the power. Keep pressing the PAUSE key until the printer completes the POST (power on self-test), then you can let go. A test pattern will begin printing. You can stop the pattern by pressing PAUSE. Turning the printer off & on again is the fastest way to end the test. This is a good page to print because it prints a large black box and it's easy to see if there are any printhead elements not functioning. It's best to use the largest, widest label you have for this test.
Hope that helps !
Aug 29, 2011 | Zebra ZM600 Printer
Hp laserjet p3015 pausing after 5 or so pages whilst printing large amounts, the printer prints 5 pages then has a pause before starting printing again, this can can make printing very slow i've...
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Aug 16, 2010 | HP Office Equipment & Supplies
I can do a test print, but the labels do not print. When I select a label from test print, the paused light gives 0ne blink, then nothing happens
Hello
Thank you for using
FixYa for your problem
you can do a rest print so we know it works, it now why is it working from the program. have you told it to use this printer and maybe you need a tech there to check settings in the program
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Datamax E-4304 Thermal Label Printer
Deleting paused and frozen there. Cannot use the
it seems you might need to rest teh PC..
Once you have done that and assuming you are running windows pls do the following (while the printer is OFF)
1. Go to "Start", "Run"
2. Type: CMD
3. press "Enter"
(now you should be in a DOS terminal window)
4. type: net stop spooler
press "enter"
5. type: net start spooler
press "enter"
6. type: exit
press enter
Turn on the printer...you should be clear now :)
Cheers,
Ed
(If this works for you, please grade this response)
Nov 06, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My KODAK PRINTER ESP3
it is a problem with print spooling. and the firmwware also needs to be upgraded of the printer . click on start, go to run,type services.msc in search boz of run. find print spooler,right click it,stop it and then start it. click on apply and the ok. Go to control panel,printers and faxes ,set ur printer as default printer.try to print after dat ur issue will be resolved
Jul 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer pauses after a couple of pages
This is normal, if annoying - it just means that the LED bar is getting too hot and the printer pauses to let it cool down. Really the only solution is to operate the printer in a cooler location.
Jul 04, 2009 | OKI Office Equipment & Supplies
HP K5400 - print pausing
print as image tick it than it will work
Jan 19, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
An extra cut about 1 inch after the invoice is printed
Go into printer friendly setup, then select the receipt printer and choose the option 'Cut at this station'. Make sure it is unchecked. Your problem solved ;)
Aug 10, 2008 | Epson TM T88 Thermal Printer
Canon LBP 1120 Laser Printer Logo
515 people viewed this question
old marine
old marine
