Question about Linksys (PSUS4) Print Server
Linksys print server psus4 held
Hi. after 1-2 hour my print server leave responding. when i try to ping my print server IP is shows "request time out" please help, everything is OK but unable to understand this problem. when i restart the print server it start working fine. but again after some time it chokes.
Check the "sleep" time...is it around 2 hours? Also, check the sleep time on the printer too.
Posted on Aug 25, 2007
  • 59 Answers
I've worked with literally hundreds of these exact print servers. The answer is really not much of an answer. The device requires a restart often because it locks up. After hours and hours with Linksys and a few custom firmware tweaks...still locks. Sometimes we just have to accept that things don't always work the way they are supposed too = "junk". Although I will tell you this, of all the print servers we have tried, this one is NOT the worst. Incidentally, there is no sleep option on that model print server. ...for what it's worth.
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
Aug 01, 2016 | Computers & Internet
I have a linksys efg 250 nas that I am trying to access. Can I get some advice on what to try next?
so you have 192.168.1.77 as the default ip address and 255.255.255.0 as the subnet mask.
What Ip address does the computer you are trying to ping have is it in the range of 192.168.1.2 to 192.168.1.76 in the dos prompt and what is its subnet mask ?
type in ipconfig
what is the equipment between the p.c and the EFG250
what connects it to the network ? A switch are cisco vlans involved or cisco port filtering ?
Dec 03, 2015 | Linksys new networking accessory efg250...
Not recognize dns
Google has many different ip addresses. They have servers I guess you call them everywhere. I downloaded several apps that looked up IP addresses cause the ping had different ones I didn't use. They all led back to GooGle owning that address. Nothing to be alarmed about, theres just no escape from Google, they see everything, track everywhere, and won a lot of different IP
Apr 06, 2017 | TP-LINK Computers & Internet
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jan 30, 2011 | Zonet ZPS2102 Print Server
Schematics for seting up a printer
Configure and wire your systems as shown in the attached power point presentation.moz-screenshot.png 5f10200.tif
Jun 02, 2010 | Linksys (PSUS4) Print Server
192.168.0.1 & 192.168.1.1
U may try this website ip-details.U will get the solution.
Apr 14, 2009 | Linksys WRTP54G Wireless-G Broadband...
Linksys not printing
as it is very old print server
u need to update its firmware ( software )
contact 1800-546-7114 for same ( linksys tech. support )
Apr 01, 2008 | Linksys PrintServer for USB with 4 port...
PSUS4 problem "talking" to Canon S330
Hi dreaddymck
I need a little more information on the setup. Is there a router in your network? If there is, is your PrintServer connected to the router and your computer is attempting to connect to the printserver through the router? If there is no router and your PrintServer is connected to your printer via the USB port and your computer is connected to one of the ports on the PrintServer via a cat5 cable, I would check to see whether you are actually communicating with the PrinterServer by pinging its IP address from the computer. If the ping is successful, then I would look at the printer properties in your computer's printer control panel and check the port configuration. Usually it is shows the IP address, port 9100 and port protocol is usually set to RAW. Otherwise I would attempt to reinstall the PrintServer using the CD originally provided. It appears to me that the server may not be publishing its IP address on your network.
--RoadHawk
Nov 27, 2007 | Linksys PrintServer for USB with 4 port...
Network printing
I am afraid, PSUS4 is an older model of print server , which supports only ordinary printers. All in ones are not supported by PSUS4. Linksys have other print server which works with all in one printers. The model number is WPSM54G. Probably you can try that. Also, if the PSUS4 is less than one month old, you can get it replaced with the WPSM54G from the stores itself . The WPSM54G can be used as wired as well as wireless to the router. If you want to use the PSUS4, you may need an ordinary printer like Office jet or laser jet with USB 1.1 version.- Thank you
Oct 26, 2007 | Linksys (PSUS4) Print Server
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Linksys (PSUS4) Print Server Logo
350 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
