Question about Motorola Mobility V3 Handsfree Headset with Connector fits MOTO Razr V3 Headset
Problem with incoming calls
The problem is that when someone calls me I can his/her voice but he/she can't hear me.
0 characters
1 Points
Once paired to my phone how do I make hands free calls and answer incoming calls?
I can only comment on my own experience with iPhone 6 and Motorola headset. I press the button on the headset and say "Call Home" or whatever. Siri repeats "Calling Home" and it rings.
Depending on phone look in the Settings for 'Voice Calling'.
May 13, 2016 | Headsets
No one can hear my voice when I make a call.
I would closely check out my "speaker" button. It may have been pressed just enough and gotten stuck, but you didn't notice it.
Feb 26, 2015 | Panasonic Kx-dt346 - 24 Button 6-line...
Auto connect/disconnect
Hi. To turn Voice Guidance off, press the Option button. To find the settings, press up or down slowly until you hear a beep. Press OK to enter the voice guidance menu. From that his menu: Voice Guidance On/Off: Use arrow keys on remote to toggle on and off. NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
Jun 14, 2013 | Jabra Extreme2 Bluetooth Headset
Receiving calls on Parrot minikit
The crossing test with an other phone will give you the explanation.
Cause the software version of one or the other product can be the reason why.
Mar 02, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
They can hear me talk but I can't hear
You are close ,go to the menu and press tool and then press the bluetooth then go to setting and press it.Make sure voice routing incoming is hands-free and voice routing outgoing hand-free
Aug 28, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth H710 new..mic not working
Go in phone to setting then go to bluetooth and press it then select voice routing incoming hands-free
Aug 25, 2009 | Motorola Mobility H710 Bluetooth Headset
How do you answer an incoming call while on a call?
Please click on the below link to view the user manual for your model.You will find all the solutions to your problems in that:
Apr 09, 2009 | Blueant Z9i Bluetooth Headset
Microphone isn't working on my hs850
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.possible you are experiencing this . i did
Dec 06, 2008 | Motorola Mobility HS850 Consumer Headset
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
Incoming calls
Try to reset the unit with the phone again.
Feb 25, 2007 | Motorola Mobility H500 Wireless Headset
Headsets Logo
22 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
