Question about Panasonic PT-53WX42 53" Rear Projection Television
Horizontal lines when I turn on tv.PT-53X42 HDTV
When I turn on my tv which i have had since 2002 it has a bunch of horizontal lines(white lines) in the picture. If i leave the tv on for about 3hours the lines gradually go away.Is there a part i can get to fix this and install it my self? Or do I have to get a profesional to install it.
  • 934 Answers
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one... But you'll need to take it in to save the pickup/delivery charges.
Good Luck!
Posted on Dec 01, 2007
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Panasoic PT-47WX49E
Jan 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Horizontal grey lines on TV
Sound like you have to turn down the G2 (screen)controls. They are turned up too high.
Jan 01, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
