Question about Maytag Performa PAV2200
Maytag performa Sparks began coming from behind the machine while it was in the spin cycle
  • Rigger Aug 25, 2007
    would that also cause it to stop?
  • 19 Answers
Sounds like your motor brushes are very worn.(Its a bit like grinding metal when a cars brake pads are worn.)Should only cost 10 or so pounds for new ones,access to the motor will be required.Unplug washer b4 changing.
Posted on Aug 25, 2007
  • Skaman123 Aug 26, 2007
    Sometimes when the motor brushes are worn you will get sparking from the motor on a spin cycle, like yourself, but they will eventually fail to generate enough power for the drum to turn at all.I would suggest replacing the carbon brushes as soon as poss.
SOURCE:
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
Dec 23, 2009 | Maytag Performa PAV2200
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Nov 20, 2008 | Washing Machines
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Maytag machine not spinning
You have a stuck brake.My advice is leaving this one alone and lrt a tech. fix it.HINT:99% of this same problems your having I have fixed without replacing 1 part,so see if your repairman can do the same.This is a PERFORMA and is know way Maytags design.Except one thing ,the name on the front panel.
May 31, 2008 | Maytag Performa PAV2200
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
May 28, 2008 | Maytag Performa PAV2200
Sparks coming from behind washer
sparks are never good, and neither are grinding noises. I suspect you might have had a motor failure. remove the belt from the drive (transmission) pulley and set the machine to spin. if you get the gringing sound or more sparks its time for a new motor
Aug 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
57 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
