Horn does not blow as strongly
There are two horns on this vehicle. Check to make sure they are grounded properly, and if you have a volt meter, disconnect the horn wire, have someone push the horn button while you check the voltage on the wire. You should get at least 12 volts. If the horn has a good ground, and is getting the required voltage, then you probably have a bad horn. Disconnect one at a time, and see how loud each of them are. This should help determine which one, if not both is causing the problem.
