Question about Asrock K7VT4A-Pro Motherboard
I really need help!
I have a 2400+ Sempron processor, Asrock K7VT4A-Pro Motherboard, 1x 256 MB RAM Kingmax, 1X 512 MB Ram Kingmax ( 768 totally) A 80 GB HDD IDE Maxtor, A 7300 GT TDH form LEADTEK. The problem is: I bought a new DVD-RW from LG but not on IDE but on SATA (since the motherboard has SATA) and from that point all hell is breaking loose. After 2 computer restarts the DVD didn't read the discs anymore. I took the dvd out but the computer is gone wild! my mouse cursor doesn't always appear and after a few minutes it freezes!
  • bogsz05 Nov 19, 2007
    ntldr is missing
    ntldr is missing
    Scholar:
  • 76 Answers
Draxxer, Got another mouse you can try. Another thing you should to is get online on another computer (of course), find and download the floppy version of Memtest86+ (not memtest86), unzip it and get it started. It will produce a bootable memory test diskette. If you don't have a floppy drive, download the .iso version of the program and burn the .iso to a CD via Nero (or whatever you have). The diskette or the CD cannot be read by Windows, so don't even try. Simply boot up the problem computer using the diskette/cd and it will automatically check for memory problems. If you see ANYTHING in Red, then you have a RAM problem. Let me know what happens. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 25, 2007
SOURCE:
A im trying to start a pc but my monitor is not startin.Asrock K7VT4A-Pro Motherboard . led red is on and my grafic card is ok
Hi, you can download a manual here:
http://asrock.com/mb/manual.asp?Model=K7VT4A PRO
Here you also find drivers.
You may have to unzip the file before installation.
Do you use the right type of ram ??
The ram module could have a defect.
Have you insertet the cpu properly ??
You can maybe try with another AGP graphic card.
Or the card is not insertet in the slot properly.
Remove the graphic card and try to clean the contact points
on the card with a piece of paper.
I guess its just a bad connection or the card is defect.
You can read all about that red led in the manual.
Aug 31, 2011 | Asrock K7VT4A-Pro Motherboard
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
I have AMD Sempron 140 on ASUS M2N68-AM SE2 motherboard, Strontium 1GB PC800 DDR2 RAM. But in system properties, the RAM is showing as 768 MB instead of 1024 MB (WinXP 32 bit). The dealer is saying the RAM...
Yes the dealer is correct that the 256 MB of your RAM is allocated to the video card of this computer since the unit has a built in NVIDIA GeForce 7025 Shared video memory (UMA)that uses 256 MB of your RAM , so if you like to maximize the use of your RAM you need to install a expansion video card.
Sep 07, 2010 | Computers & Internet
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
Not so much a problem but I have an old Dell dimension with an 866 inteleron processor. I have 2 slots for Ram, each with 256 mb totalling 512, my question is can I replace them with 2 512's for 1plus gb...
Yes you can install 2 512 mb RAM for 1Gb in motherboard.But make sure both 512 RAM are same in configuration and frequency it is better you purchase both ram of same company.Then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 23, 2009 | NEC Pentium III , 866 MHz Processor...
My sony Vaio has been upgraded to 2x 512 mem from 1x 512 plus 1x 256, which recognised as 768, it will not recognise the exra mem, both 512 m are kingston PC 266 should be compatable with the comp, any...
Yes if the FSB is not the same you can have this complex mutual,necessary if the FSB is 266 should be included is the 266 also, although it is both same MB size.may also be secondary to that are other video memory you please check the BIOS settings only.I already help you and them good luck only, good day.
Oct 22, 2009 | Computers & Internet
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Asrock K7VT4A-Pro Motherboard Logo
514 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
