I installed a logitec webcam and want to invite folks to view it with Yahoo IM and it says the webcam isn't connected. All else works on it, except that function. Help!!!!!!!!!!I installed a logitec webcam and want to invite folks to view it with Yahoo IM and it says the webcam isn't connected. All else works on it, except that function. Help!!!!!!!!!!
You can't post conmments that contain an email address.
Windows Vista is a old version of operating systems, you facing a problem with your router can not connect with your Vista PC. DON'T WORRY uninstall Windows vista and again install Windows 10 latest version on your pc and already troubleshoot router not connected your pc problems. OR Call Windows support number USA 1-844-602-3987 (Toll-free) and find instant support.
Does the EUB-362/362EXT/862 work with Windows Vista?
No,
the EUB-362/362EXT/862 Client Utility was written for use with Windows
2000/XP. Microsoft Windows Vista users must use the "Connect to a
Network" utility in Windows Vista.
I am currently running Windows XP on my PC and upgraded it to a Windows Vista operation System does a USB driver exist for Windows Vista that will allow me to connect to my Panasonic KX-TDA 200 Phone System.
chek whther those driver supports vista?othwise try to find out vista drivers from site.....and even try manual connection through network connection...
The trick with XP also woks eith VISTA too. Try the following in vista, you will succeed.
If you're using a RAS / PPPOE connection for
Internet, and wish to automatically connect to your ISP at startup, you
may use Rasdial utility which is built-in.
Usage: Open a Command Prompt window and type:
Rasdial <connectoid> "username" "password"
This
would initiate a dial-up/PPPoE connection to your ISP. You can create a
batch file with the above parameters and place it in your Startup
folder, so that vista dials to your ISP automatically at every startup. If
you don't prefer to enter the password in the batch file, use the
following command-line (vista will prompt you for a password - secure)
Rasdial <connectoid> "username" *
NOTE: Type Rasdial.exe /? in the Command Prompt to learn more about this command, it's other parameters.
Hope my info helps you, Thanx for using fixya, Cheers.
use nokia pc suite
get the right settings on your phone
there is no prob with vista as far as i know
pair the phone and comp properly via bluetooth or USB
and i think youll have a good connection
I have a new HP laptop with Vista Home OS, and I just installed my HL-1440 with a driver that was installed automatically in the "New Printer" procedure in Windows, and it works perfectly.
