Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
My bushnell tour v2 range finder is stuck on 1888 yards divided by 18 equals 888metres what do I do to fix this
    New Friend:
I have a Bushnell Tour V2 that has worked very well for over 8 years and it just started doing the same thing with the frozen screen and 1888 yards. Since I just replaced the battery that I bought at a Pro Shop about 6 months ago I thought the battery was fine. I looked at the battery and did not recognize the brand so I went out and bought a new Copper Top Duracell and BANG it is working again just like new.
Posted on Apr 12, 2019
SOURCE:
SOURCE: Bushnell Tour V2
This happened to me on the first round of use. I replaced the battery and it worked fine. I guess the battery that came with the unit was not very good
Posted on May 25, 2008
  • 16 Answers
SOURCE: Bushnell Tour V2..no display
If the unit gets hot (like in the trunk of a car), the LCD display will go out. Keep it in the house and it should get better when it cools.
Posted on Oct 15, 2008
  • 133 Answers
SOURCE: Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Posted on Apr 11, 2009
SOURCE: Bushnell Laser Range Finder
you have it on the meters setting not the yards setting. hold the scan button down for three seconds or longer and it will revert to the other form. a meter is nearly 10% longer than a yard.
Posted on May 06, 2009
  • 133 Answers
SOURCE: Bushnell Rangefinder Tour v2 E31 appears in viewfinder
If it is 2 years or less from the date of purchase.....send a copy of the POP (proof of purchase) or call them......! It should be under warranty. This is the real deal!!!
rate if you can!!
MTG
Posted on Jun 25, 2009
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
Range finder fell in a cooler
My tablet got wet. I put it away in my room and forgot it for 3-4 weeks. When I found it and tried it - voila! It worked perfectly.
May be thats a solution.
May 09, 2014 | Bushnell Tour V2 Pinseeker Laser...
Son just bought me a Bushnell Banner Dusk&Dawn 4 Plex, Mil-dot, 3-9x50E. Just looking for an explanation on all the marking on the reticle (inside of the scope) I understand the cross hairs and how to...
Simply put, the Mil-Dot is a way to estimate range with the scopes reticle. This type of reticle was developed for military applications. The space between the dot centers is equal to one milliradian (Mil). hence the name mil-dot. One Mil equals 3.6" inches at 100 yards, or 36" at 1,000 yards. To use this system effectively you must know the size of the target. For instance most people are an average of 6 feet tall or 2 yards. The formula used for determining range to the target is (size of target x 1000 divided by number of mils the target covers). Hope this helps FixYa up.
Aug 28, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Bushnell Tour V2 2nd Distance Digit Missing
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Jan 14, 2010 | Bushnell Tour V2 Pinseeker Laser...
How do I change Meters to Yards
Hold down the button on the side for at least 5 seconds. The "Y" will appear in the display....Now its set back to yards.
mtg
May 26, 2009 | Bushnell Tour V2 Pinseeker Laser...
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Pinseeker 1500 just illustrates 1888 YM
Here's where you can get the manual:
http://www.bushnell.com/customer_service/manuals/rangefinders/20-5103_Pinseeker.pdf
I'm having the same problem, but the normal yardage seems to be working fine. I tried calling Bushnell, they said I would have to send it in to them and they would fix it. I'm thinking it's got to be something easy to fix.
Does anyone have any answers?
Oct 18, 2007 | Bushnell PinSeeker 1500 20-5103...
Bushnell Range Finder
I have the same problem, and sent my unit to Bushnell for repair. They were unable to repair it, stated "obsolete" and "repair parts unavailable" and sent it back to me. Would you be interested in selling me your dead unit for parts for a few bucks? Thanks. genebaker@yahoo.com
May 27, 2007 | Bushnell Yardage Pro Tour XL Rangefinder
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
1,165 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Goldi Kunal
Damen Wong
Damen Wong
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
