Question about Gigabyte GA-6WMMC7 Motherboard
NOT STARTING UP
I a problem with this motherboard. When connected to the power and with ram and processors, it does not power not even the light on the board. But i have also noted that when connecting the power to the motherboard before it is completely inserted the LED lights and funs rotate but nothing comes. when I insert completely it again goes dumb. Kindly assist. email: info@afrosoftweb.com
  • WALTER OMBIRO
    WALTER OMBIRO Aug 24, 2007
    Thanks sandrew, but i don't think it is issues to do with the mains connection because i have left if for long without connections, I have also tried connect it without the processor (800MZH/256/1.7) and have even interchanged with three other processors.
    From the observations i even thought that a component on the board might not be functioning. I have also tried powering the board even minus the processors but it too does not power.
    I rest the bios, and removed the battery completely from the board for a long time. I finally removed the jumber selector for the bios.
    President:
  • 2,961 Answers
This is a sign that you have the power,reset etc connections onto the motherboard wrong. Double check the connections as you may have them pined the wrong way round, you will also have to remove the power plug from the mains and the back of the pc to allow the board to reset the power settings, this will be why the fan runs then stops when fully inserted; as the connections to the front panel are connected wrong
Posted on Aug 24, 2007
  • andrew pester
    andrew pester Aug 24, 2007
    i wasnt refering to it being a mains problem, the removal of the plug just clears the power from the board, i still think the connections to the front panel power buttons are wrong, unless you are trying to get it to run without being fitted into the case, if its in the case check for shorting on the underside of the motherboard to the casing
  • andrew pester
    obviously if it has always been connected the same to the terminals and you have never touched the connections then ignore last comment
The 945GCT-M3 motherboard wireing diagram for the power sw and power led
power connecter has totally 9 pins on the board but actually we have to use only 8 pins please refer the attached image
if you have further any doubts post me
Feb 26, 2012 | E-Machines Computers & Internet
Need the pin Config for the Motherboard pwr switch and hdd switch for a Emachine T2672 and pwd led thanks
Pin Configuration = Pinout
The Front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables (Wires) go to, is the Front Panel header.
Front Panel header pinout.
The motherboard used in an eMachines T2672 desktop computer is an FIC AU31 motherboard.
Made by First International Computers (Inc.) for eMachines.
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31.shtml
Orient the motherboard like it is in the photo, so we are both looking at it in the same direction.
{Processor to the top, Ram memory slots to the right, white PCI slots to the bottom. The way it sits in the computer case}
The Front Panel header, is a small black rectangular block that sits horizontally, at the far right bottom corner.
It has two rows of pins.
4 across the top, and 5 across the bottom.
(The small rectangular block above it, is for connecting a Power On LED light that has 3 wires. More on this in a moment)
The pins are numbered.
The pins are numbered Evenly across the top, and Odd across the bottom.
Starting from the Left side going across to the Right, on the Top row;
Pins 2, 4, 6, and 8.
There is No Pin 10.
Starting from the Left side going across to the Right, on the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
Pin 1 is for the Positive wire ( + )
(If the LED light is dim when operating, switch the wires around)
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Reset button)
C) Pin 9 is Not Used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light, IF it is a 2 wire LED light.
Pin 2 is for the Positive ( + ) wire.
(If the LED light is dim, switch the wires around)
If the Power On LED light has 3 wires:
Use the Power On header above the Front Panel header.
This rectangular block has 3 pins.
Starting from the Left side going to the Right; Pins 1 , 2, and 3.
Pin 1 is for the Positive wire.
Pins 2 and 3 are Ground wires.
E) Pins 6 and 8 are for the Power On switch. (Power On button plastic assembly has an ATX power on switch inside it)
This is a link to a free motherboard manual, for the FIC AU31 motherboard. It is in Zipped file form.
(A Zipped file is a compressed file. It is used for one, to send a large file over the internet)
If you do not know how to unzip a file, post in a Comment, and I'll lead you step by step.
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
In the list on the left side, left-click right on the file name - AU31
For additional questions please post in a Comment.
Regards,
joecoolvette
[ P.S.
The motherboard chipset is an Nvidia Crush 18G + MCP AGP
It is an Nvidia Force 2 chipset,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#nForce2
Supports Processors that are AMD, and fit in a Socket A processor socket.
(Socket A is also known as Socket 462)
Supports AMD processors that have either a 200MegaHertz Front Side Bus, or a 266MHz FSB, or a 333MHz FSB.
AMD Athlon XP processors with either a 266MHz FSB, or 333MHz FSB.
From the 1500+ model up to the 2800+ model.
AMD Duron processors with a 200MHz FSB.
From the 800MHz to the 1.3GHz models
(AMD Athlon XP is the top of the line. Then it's Duron, then Sempron.
A Sempron processor has half of the L2 cache that a comparable Athlon XP does)
Ram Memory is DDR Sdram at either 200MHz, or 266MHz, or 333MHz, or 400MHz.
Depends on the Processor used.
(Ram Memory typically operates at half of the frequency rate ('Speed') that the Processor does.
If the processor's FSB is 333MHz, you can use 400MHz DDR Sdram. {PC3200}
Confusing I know.
DDR Sdram is 'double-pumped'. It is actually 200MHz for PC3200.
This is close to half of 333MHz.
Processor has an FSB of 266MHz? Ram memory used will be 266MHz. Remember, it is actually 133MHz for the ram memory. (PC2100)
Need an AMD Athlon processor?
I found this place years ago. Not advertising for them. Just computer geeks sticking together, and sharing information. (I have bought a motherboard from them, and it works fine),
http://www.weirdstuff.com/cgi-bin/category/10201
Sep 04, 2011 | E-Machines eMachines Desktop PC
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Starting at the Bottom on the Left side going Up;
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Compaq EVO 510 2.4GZ Motherboard Question
YOU MAY HAVE TO CALL HP /COMPAQ TO SEE IF YOU HAVE THE RIGHT MOTHER BOARD FOR THAT PC
Jan 08, 2010 | Compaq Evo D510 Minitower (Open Box)...
I try starting up and i can't even get as far as the bios screen anymore it just redlights(d30)on the motherboard and i have to hold down the power button to get it to reset to start again. wont' power any...
problem is usaly RAM try changing it, problem could be also CPU
u can change that also, or your motherboard is dead...
I can help u fix your problem but u have to tell me more obaut that problem?
Do you hear any sounds like beeps?
Nov 03, 2009 | Shuttle AN35N Motherboard
D500 Latitude
Open the cover. Put out the RAM and insert again. Do the same with Processor. Recheck all the outer connections. It may solve the problem. (ehteshamhusain@gmail.com)
Jun 24, 2009 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Motherboard not starting Bios but fans start
Yes, had exactly the same problem earlier this week, the bios chip may be faulty, as you know all other components work, so it's down to the motherboard and a replacement is required
Mar 22, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Gigabyte GA-6WMMC7 Motherboard Logo
163 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
robert roberts
MegaByteMe
MegaByteMe
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
