Cars & Trucks Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CATALYTIC CONVERTOR - BANK 2
I HANVE A 2005 MITSUBISHI GALANT GTS. THE CAR COMES WITH 2 CATALYTIC CONVERTORS. MY ENGINE LIGHT CAME ON, AND I TOOK IT TO GET A DIAGNOSTIC, AND WAS TOLD I NEEDED TO REPLACE BOTH CATALYTIC CONVERTORS. I TOOK IT TO AUTOZONE, AND GOT A PRINT-OUT OF THE CODES THAT CAME UP, AND THE TWO CODES THAT DID, BOTH RELATE TO THE OXYGEN SENSORS AND THE CAT ON BANK 2 ONLY. I NEED HELP FIGURING OUT WHICH CATALYTIC CONVERTOR REPRESENTS ''BANK 2.''
  • 3 more comments
  • td92 Mar 26, 2009
    CODE NUMBERS WERE P0431 AND P0432
  • td92 Mar 26, 2009
    I HAVE ABOUT 81,000 MILES ON THE CAR. WHAT DOES THE O2 SENSOR BEFORE THE CAT DO?
  • td92 Mar 26, 2009
    OK, UNDERSTOOD. I ACTUALLY BOUGHT SOME BOSCH PLATINUM SPARK PLUGS A LITTLE WHILE AGO, BECAUSE I WAS GONNA TRY AND DO THE TUNE-UP MYSELF. PROBLEM IS 3 SPARK PLUGS ARE RIGHT IN FRONT, WHEN YOU POP THE HOOD. THE WAY THE ENGINE IS DESIGNED THOUGH, THE OTHER THREE ARE REALLY DIFFICULT TO GET TO; I THINK I WOULD'VE HAD TO TAKE OFF A BLOCK IN ORDER TO REACH THEM......I JUST GOT A PRICE OF ABOUT $200 TO GET THEM CHANGED, SO I'LL DO THAT, AND HAVE THE O2 SENSOR CHANGED ALSO, AS YOU RECOMMENDED. HOPEFULLY THE CAT IS FINE, BECAUSE I THINK IT'S THE ONE DIRECTLY CONNECTED TO MY EXHAUST MANIFOLD, AND FROM WHAT I'M TOLD, THE DEALER CHARGES $800-900 FOR THAT CAT! THANKS FOR YOUR HELP DAVES, YOU ARE THE MAN!
  • Dave  C
    Dave C May 11, 2010
    What were the code numbers ?
  • Anonymous Apr 01, 2014
    Catalytic convertor red hot.
Dave C
Level 3:
President:
  • Master 1,050 Answers
  • Posted on Mar 26, 2009
Dave  C
Master
Level 3:
President:
Answers
1050
Questions
Helped
527079
Points
4030
You have a V6 engine, bank one is the row of cylinders on the passenger (right) side, bank two is the row of cylinders on the drivers side (left). Your codes indicate an inefficiency in the cat on the left side but this could be due to a bad O2 sensor or an engine that is out of tune and overloading the cat. This car seems too new to have a bad cat. I would change the plugs and the O2 sensor after the cat before going any further. The reason I say the O2 after the cat, it's the one that is critical in sensing cat efficiency. What is the mileage?
  • Dave  C
    Dave C Mar 26, 2009
    The O2 before the cat regulates the air fuel ratio that the engine burns and the O2 after the cat checks for complete oxidation within the cat. The whole system falls apart though if the engine is missing, even a small imperceptible amount. A miss introduces oxygen into the exhaust stream and confuses the computer. It is critical that you have good spark plugs. For the life of me, I've never understood why manufacturers have started recommending 100,000 mi spark plug changes. I guess it is so they can market the car as "maintenance free". Even with platinum plugs, there is too much at risk, catalytic converters are far more expensive than spark plugs, let's say every 40,000 mi!
    It is possible that your cat has been damaged and will need to be replaced, but you would be crazy to spend the money on new one without replacing the spark plugs as this is what no doubt would have damaged it in the first place. What I've suggested is a shot, but a good one that would have to done regardless. If you really want, you could do the front (sensor 1) O2 as well but they are expensive and I'm trying to be conservative.
2answers
Where is location of b1s2 o2 sensor on 05 mercury mariner 3.0 v6
Bank 1 is the side that your #1 cylinder is on and Sensor 2 is the down stream sensor. If I remember correctly, your car only has 3 sensors, so it is the one after the catalytic converter. If you do have 4, it is the one after the bank #1 cat.
2answers
Where is Bank 1 Sensor 2 on a 2004 Mitsubishi Endeavor?
Bank 1 is the driver's side manifold on a "V" engine or the main exhaust on an inline engine. Senosr 2 is exactly that, the second O2 sensor in the exhaust, usually after the catalytic convertor. Hope this helps.
1helpful
2005 jeep have 4 oxygen sensors 1 bad its 2 bank is it the upper or lower one
DESCRIPTION The Oxygen Sensors (O2S) are attached to, and protrude into the vehicle exhaust system. Depending on the engine or emission package, the vehicle may use a total of either 2 or 4 sensors.
On this emissions package, 4 sensors are used: 2 upstream (referred to as 1/1 and 2/1) and 2 downstream (referred to as 1/2 and 2/2). With this emission package, the right upstream sensor (2/1) is located in the right exhaust downpipe just before the mini-catalytic convertor. The left upstream sensor (1/1) is located in the left exhaust downpipe just before the mini-catalytic convertor. The right downstream sensor (2/2) is located in the right exhaust downpipe just after the mini-catalytic convertor, and before the main catalytic convertor. The left downstream sensor (1/2) is located in the left exhaust downpipe just after the mini-catalytic convertor, and before the main catalytic convertor.
Left and right are distinguished by sitting in the vehicle, not looking at the vehicle from the front
1helpful
2004 galant cat converter replaced now engine knocks
Catalytic convertor is just an emission control device, It help eliminate harmful gases into our atmoshper,as for the engine knock it had nothing to do with it,
1helpful
2answers
The vsc light and the trac off light and check engine light all came on at the same time code p0420 comes up on my 2005 highlander what does this mean?
A p0420 sets after Engine and catalyst are warmed up, vehicle driven within set vehicle engine speed range and waveforms of heated O2 sensors bank 1 sensor 1 and bank 1 sensor 2 have the same amplitude.
Catalytic convertor and O2 sensors need to be tested
1helpful
2answers
The computer show's 02 sensor bank 2 stuck and to lean, which one is it their are 4 of them on this truck
bank 1 sensor 1 is driver side exhaust pipe in front of catalytic converter, bank 1 sensor 2 is drivers side exhaust pipe behind catalytic converter, bank 2 sensor 1 is passenger side exhaust pipe in front of catalytic converter, bank 2 sensor 2 is passenger side exhaust pipe behind catalytic converter.
1helpful
2answers
I have a problem with check engine, in the scanner is appear the code P0136 O2 1/2 and I do not know which sensor is this, my car is a Mitsubishi Galant 1998 the engine es 4G64 2.4cc
p0136 02 sensor malfunction is (bank 1 sensor 2)-- replace 2nd 02 sensor thats in exhaust system. If it is a four cyclinder, then there is only one bank. if its a six then bank 1 is on the side of # 1 cylinder. bank 1 sensor 2 is after convertor. have a good day !
1helpful
2001 dodge durango 4.7liter 4x4 i replaced front o2 sensor,rear 02 sensor,ground wire to exhaust and the engine light keeping coding saying (o2 sensor heater curcuit malfunction bank 1 sensor 2). car runs...
bank 1 sensor 2 is the left downstream sensor (1/2) is located in the exhaust downpipe just after the mini-catalytic convertor, and before the main catalytic convertor. Now the meaning of this is that your not getting any 12+/12- heating on sensor, which means voltage is supplied to heat sensor up. You have a O2 sensor heater relay, but not getting problem with 2/2 sensor tells me you need to check/inspect the wiring for 1/2 sensor, open wiring for 1/2 sensor and inspect
7helpful
2answers
2005 gallant with O2 sensor engine light is one...how do I fix it?
have the engine light code scanned, and it'll tell you if it's bank 1 sensor 1, bank 1 sensor 2, bank 2 sensor 1, bank 2 sensor 4.
Bank 1 is on the same side as Cylinder 1
Bank 2 is on the opposite side of Cylinder 1
Sensor 1 is located before the catalytic converter.
Sensor 2 is located after the catalytic converter
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
