Question about Motorola Mobility RAZR V3
MotorolaV3x power up
When i switch the power on the key pad will light for a few seconds and then off again. I could no longer power up my phone. But before this happened, i observed that sometimes the screen turn to all white and by closing the screen it turn back to normal operation. As of now my phone could no longer power up. Any one who could suggest a solution for this kind of problem. Thanks
    Problem Solver:
  • 5 Answers
You have a brocken flat cable problem. You should buy and replace it, or find someone who kow how to do that.
Posted on Aug 24, 2007
I called myself programming the new keys for my pt cruiser, but,it didnt take. At first it would start and run for a few seconds, now it wont turn over.what did I do wrong and how can I fix this?
Takes the master key to get it started again. The security gives you 3 tries to get the vehicle started, after the third time, it kills the starter.
2002 Chrysler PT Cruiser Note: You must have two valid keys to add a new key to the system.
1. Insert the first valid key into the ignition switch. Turn the ignition switch to the
ON/RUN position for at least three seconds, but no longer than 15 seconds.
Then, Turn the ignition switch to the LOCK position and remove the first key.
2. Insert the second valid key into the ignition switch. Turn the ignition switch to
the ON/RUN position within 15 seconds. After 10 seconds, a chime will sound.
In addition, the Vehicle Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert the new key into the ignition switch. Turn the ignition switch to the
ON/RUN position.within 60 seconds. After 10 seconds, a single chime will
sound. In addition, the Vehicle Security Light will stop flashing. To indicate that
programming is complete, the Vehicle Security Light will turn on again for
seconds and then turn off.
The new key is now programmed. The Remote Keyless Entry transmitter will
also be programmed during this procedure.
Repeat this procedure to program up to eight keys.
Oct 09, 2016 | Cars & Trucks
Tip
How to hard reset or factory reset T-Mobile G1 phone
Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory.
Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
  1. Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
  2. Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
  3. Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
  4. After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
  5. Next, press 'Alt+W' key (to factory reset it)
  6. Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
  7. The reset is complete.
on Feb 25, 2010 | T-Mobile G1 Android HTC Google Smartphone...
I have a ZTE Boost Mobile phone and my screen will not let me swipe it to unlock it and I would like to know what to do to fix the problem. My volume and power button works but that is it.
first check your TOUCH pad working or not if not than its Hardware problem, replace Touch pad and check it out. if not working than try to hard reset by switches
  1. Turn off your phone.
  2. Press and hold Volume Up + Power at the same time for a few seconds.
  3. Release held keys when you see Recovery Mode.
  4. Then press Volume Down to select option "Wipe Data/Factory Reset", and press Power button to confirm.
  5. Well done!
Apr 17, 2016 | ZTE Cell Phones
My phone is not going from the nokia startup screen
Just follow the steps
Make a backup of contacts in your another sim.
Switch-off your phone.
1. Press and hold theree keys at a time;
You will use three finger for pres three keys .dial switch 3 key(from key pad) star( *) and pres the on switch.
Green dial key,
* Star key,
No. 3 key
Then Power on/off to swtich on the phone.
All switch will be pressed at a time.
.Soon an formateing text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full
phone formatting completed, your phone will back to original system and factory settting.
Hope this helps.
Jan 16, 2011 | Nokia N73 Cellular Phone
Code ? 1209
Green dial key,
* Star key,
No. 3 key
Hope this helps.
Jan 16, 2011 | Nokia 1209 Cell Phone
Car wont start
IIf doesn't crank then problem with neutral safety switch, starter solenoid, starter or ignition switch. If cranks then could be bad crankshaft sensor, bad ignition coil pack, blown injector(s) but usually you will get a stall beforehand. Fuel pump could be dead, turn key to ON (not starting) and listen for a few second hum as it primes the fuel rail. Also check to see if check engine light comes on for a few second with key to ON, if not then not powering up due to shirt or bad. Possible but rarely the fuel filter is so clogged it no longer allows fuel, but usually will allow start after sitting.
Sep 03, 2010 | 1998 Lincoln Continental
Cannot get my key pad control to light up. I have
they clearing the memory by holding down red and green buttons, then try pairing again, the password is 1234, if this does not cure it you will need a parrot software update. if in doubt try Parrot.com and find a local acredited engineer they will sort it out.
Feb 22, 2010 | Parrot 3000 Evolution Advanced Bluetooth...
Nokia 5310 xpressmusic jammed
may be ur keypad no matching ur circuit or u use duplicate key pad. so its way 2 go tecnication and it will become ok. dont worry
Jul 29, 2009 | Nokia 5310 Cellular Phone
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
The phone dosnt switch on
it may sound funny,, but keep your phone in sunlight for a whole day........ I personally had that experience with my 6630,, may be just a chance,but it worked..
Jan 24, 2008 | Nokia 6600
Motorola Mobility RAZR V3 Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
