Question about Motorola Mobility C168 Cellular Phone
C168 Keypad not working
I got a call & when i tried to receive no button on the keypad works, then have taken the battery & sim card out once & put them in, it shows the set time screen & as before the no key is working.
Motorola c168 all keypad not work solution
Posted on Apr 19, 2010
New Motorola SLVR is suddenly unresponsive, won't turn on
Try to replace the battery and if the unit is still under warranty advise the store to replace the battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Keypad for chamberlin garage door opener stopped working
You need to reprogram the keypad. Press and release the learn button on the back of the motor. Within 20 seconds, press your four digit code into the keypad and press and hold the enter button until the lightbulb on the motor blinks once. You are finished.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad
Hi If you tried many many time to solve it and not succeces to solve. I think this is may be software problem so you can reload software.
Oct 14, 2008 | LG C1500 Cellular Phone
My buttons on my cell phone...
Hi tina. Looks like the keypad of your phone is screwed. You will need to get a replacement keypad and it will be up and running again.Good luck!
May 23, 2008 | Motorola Mobility RAZR V3
KEYPAD???
Usually this means that you need to take it to a repair shop to have the keypad replaced but truthfuly it would be cheaper just to get a new phone. Hope this helps =)
Feb 24, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
No response from keypad input?
check your volume keys or any side keys that get stuck... or if you can open your fone check its keypad for any shortage...
Oct 26, 2007 | Samsung SGH-d407 Cellular Phone
Can only receive calls and turn the phone on and off! cannot dial out, access my contacts, ect., keypad not working at all.
If you are comfortable taking part of the phone apart there is something you can try. Remove the two Torx screws right below the battery. Gently pull the plastic cover loose. There will be a cable that connects this portion of the phone to the keypad/LCD/etc. Clean the connector on this cable and the connector it was plugged into with 99.5% Isopropyl alcohol. Reseat the cable and the part of the phone you removed and replace the screws you removed. If this does not work the keypad flex on the phone is probably damaged and will need to be looked at by a repair center.
Sep 07, 2007 | Motorola Mobility RAZR V3
Keypad will not work
This happened to mine after I got the Razor wet - I pulled the battery and the sim card, blew it out with a can of compressed air and it worked for about 8 months. Then it got hot out in my car and started doing the same thing - blowing it out hasnt worked again-
Jan 22, 2007 | Motorola Mobility RAZR V3
Broken phone!!
Saw quite a few of these. Have you tried taking the battery and Sim out while the phone is still on? did you try to flash your firmware on your Razr? there is one firmware will mess up your keypad, but all you have to do is apply keypad flex and it will work again. A friend recently updated his firmware and had to re-apply flex, works fine now. Good luck!
Jun 09, 2006 | Motorola Mobility RAZR V3
Motorola Mobility C168 Cellular Phone Logo
159 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
