Question about Fujitsu Siemens X19-1 19 in. Flat Panel LCD Monitor
Problem with my Fujitsu-Siemens Scaleoview X19-2 Monitor
The image keeps flickering, and I checked the cables, I pressed the Auto-Configuration button, as it says in the manual, nothing seems to help. It is set to its best resolution, 1280x1024. Could you also provide me the data sheet? Thanks a lot! Adela
5 Suggested Answers
  • 3085 Answers
SOURCE: i need alimentation cable but i don't know his
AC Adapter.?...Check eBay.
Posted on Aug 15, 2009
SOURCE: i have a fujitsu siemens
i have the same problem :(
Posted on Sep 05, 2010
  • 11361 Answers
SOURCE: Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 13, 2010
SOURCE: Fujitsu siemens scenicview p17-2 monitor flicker.
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Posted on Oct 24, 2011
Blue Desk Light keeps blinking
not recommended but yes it might just be a loose connection or dry joint, just be carefull there are live capacitors inside which might shock you
Jul 15, 2014 | Fujitsu Siemens Monitor Sh ScaleoView , 19...
Osd locked fujitsu
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Sep 16, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Monitor in on/off loop. If hold select button down you can see the PC is diplaying but monitor keep going off then on. Also can hear the relay clicking in the monitor.
That is a bad one. Sounds like you need a new relay. I know that is no help. Check the power cord, (believe it or not, they can have too little power going through if they get damaged or weakened by something). Check CLOSELY the video cable to computer connections. touch the ends and nearby cable ends while observing monitor to see if it flickers at the same rate of your movements. Try another monitor to see if it does the same thing. I can't help with much else on this. Good luck
Jun 02, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
Fujitsu Siemens Scaleoview C17-2 need pinouts (voltages from high voltage board)
you have to see on fujitsu Siemens page, for this supporting solution, there is a forum.
good luck
Open Sky
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
272 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
