Question about Acer AL1715 17" LCD Monitor
Acer auto config
I have an acer flat panel LCD moniter (not sure which one) that has worked perectly for three years. Then one day (with no new hardware or software added to the computer) it decides that it will keep flicking up with 'auto config please wait which flashes on and off the screen. THIS IS ANOYING AS HELL. I'v checked that the resolution is set to 1280x1240, and the refresh rate is 60Hz
  • 2 more comments
  • Anonymous Nov 03, 2007
    some problem here with AL 1916W
  • Anonymous Nov 04, 2007
    I'm having the same problem - Ryan
  • Anonymous Nov 16, 2007
    I too have an Acer X193W and want to stop the "Auto Config" from appearing... can someone help please!!!
  • luke123 Dec 17, 2007
    I worked out with problem. To fix all you need is a good hard FLICK on the auto-config button. If not a wack with something harder. There must have been something inside not quite right, perhaps something sticking it down. Trying to pull it out didn't work, but a HARD flick did the trick for me.
Same here never buy a freaking acer
Posted on Dec 17, 2007
SOURCE:
The picture is very wavy and fuzzy sound is perect
Depending on the specifics of your tv (flat screen LCD, LED etc, Plasma, or CRT)
Unfortunately sounds like ghosting / indicative of Bad Panel.
BUT to be sure ...
Double check picture settings to be sure setting inadvertently changed. try using Component to be sure connection isn't problem
Mechanically
COULD also be defective T-con, or in plasma a sustain board can create issues. (for a TV shop to determine/ high voltage is present so not for the untrained)
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 30, 2018 | Televison & Video
Dear sir/madam, I have a proview TFT moniter problem,when i on moniter than i found no display is appearing.
please check the moniter with different pc it can be the complaint with LCD panel.it is replacable plz vote
Mar 03, 2011 | Proview PA-32JK1A 32 in. LCD Television
I just purchased a acer moniter ...I plugged it in and the picture looks a little distorted (my grand daughter says I am not use to the new flat screen) on the moniter was a film cover that said make sure...
If your on XP you can right click on the empty desktop and go to properties, Under the settings tab you will find options for screen resolutions. If your on Vista or 7 you right click on empty desktop space and go to screen resolution, There again you will easily find your settings for your screen resolution. Click apply and then click OK after that lay back and enjoy your screens clarity.
Apr 25, 2010 | Acer X183HB Monitor
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
I have an HP Pavilon, Laptop and an Acer Monito
you can buy a lcd cable to connect your laptop and your acer moniter.
if your moniter is a crt then no need to buy you can use the default cable.
if its a lcd the cable is given in that package. you can use it.
you can see a vga port in your laptop with blue colour that is the connector for moniter and your laptop
Jul 14, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Flatscreen didn't have a CD
I bought this monitor brand new and as I recall there was no software in the box.
Aug 03, 2008 | Balance CM2015 15" LCD Monitor
KDS Moniter
Have you checked your video card or adapter?
Check the settings on the monitor itself.
If you didn't find the problem go into system properties (windows logo + pause)/hardware/device manager. Expand monitor/right click and see if your new monitor is listed. Is there a yellow or red symbol next to it? This would mean a problem, then right click symbol/properties and error will be shown.
Could be a memory issue.
Don't forget to try a "working monitor". This will narrow it down a bit.
Jul 14, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Hp flat panel monitor looses picture
Here
Here
and Here
I've tried all the aforementioned fixes, and my conclusion is... when your monitor's dead it's dead. Go to NewEgg and and get a new one.
Nov 12, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Acer AL1715 17" LCD Monitor Logo
1,163 people viewed this question
Ekse
Alun Cox
