Question about Nokia 1600 Cellular Phone
A dark line appears in the bottom of the display
I have bought nokia 1600 yesterday.when i was about to call my partner a dark line appeared in the bottom of the display.it is not going at all. it appears even if we are going to any other option
  • 490 Answers
In ur handset there is a chip which connects ur screen card with working of rest of phone memory...problem is there.reinsert sim and try else take it to the service centre
Posted on Oct 12, 2007
SOURCE:
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
This s ma imei no:356812029244892.. pls give me a reset code
Hi There
You mobile unlock code is mention below as you IMEI number, if you are not success then try the below instruction to unlock mobile.
IMEI Number
356812029244892
Unlock Code:
7462056640
Warning : Do not enter any wrong unlock codes on your Nokia 1600 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1600 mobile phone, your phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 1600 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1600.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1600 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1600 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1600
Thanks
Prashant
Nov 29, 2011 | Nokia 1209 Cell Phone
How to unloack nokia 1616 security code ?
Hi
For unlocking you Nokia need IMEI no of your mobile, send me that no otherwise the use this instruction.
Cheer
Jul 17, 2011 | Nokia 1616 Cell Phone
I bought a new hp dv2000 laptop 2 yrs back. till date it was working very fine sudenly yesterday morning when i powered on the laptop thin lines appearing on the screen display... i tried to on the system...
honestly the problem is in your lcd display. it is already defective lcd. replacement of lcd is much expensive. it would be better to buy a new unit rather than replacing the lcd.
Feb 08, 2010 | HP Pavilion dv2000t Notebook
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Help me to fix my nokia 1600
do ressttting your phone code 12345
Dec 22, 2007 | Nokia 1600 Cellular Phone
Contact service
I too got this problem only , Its the software problem yaar ,They will reinstall the OS
Aug 28, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
