The control Panel times down about 10 minutes in each cycle and gets stuck at that point. Example. If the cycle is scheduled to run for 50 minutes, the washer will start, go through it cycle until the control panels shows 40min remaining. The washer continues to run but it stays stuck at 40 minutes and will continue to run forever. This will happen in each different cycle chosen.
Hi
If the cycle doesn't complete, check these:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
