Question about Sony Ericsson P990i Cellular Phone
Touch screen calibration
How to calibrate p990i touch screen
  • 15 more comments
  • tarar Dec 05, 2007
    my P990i touchscreen adjustment with stylus is gone out. i.e when i touch the screen it senses at a far point from the tuoch. i have tried to go a master reset but it dont do any difference and still i have to tap the screen about an inch above the point i want to. plz help me in this regard
  • sssjan Dec 28, 2007
    i try many time to touch screen, but it doesn't work. i mean that when touch number one it show number two.
  • hicham Jan 03, 2008
  • praveeblr Jan 23, 2008
    Sony Ericsson P990i touch screen problem, does someone know how to fix the issue.
  • microb Jan 29, 2008
    When I hit the center some part above gets highlighted and selected and
    the botton part where the taskmanager and battery icons are present
    does not respond to my taps ... what could be the problem,,, kindly
    help me solve the issue.
  • ygudetti Feb 03, 2008
    I have P900 and I cannot touch key pad icon and looks like touch bscreen is not working at the bottom portion.
    Any help greately appreciated.
    Thanks,
    Yohan
  • Anonymous Mar 04, 2008
    The touchpad is not callibrated. Have taken my phone to the local agent. Their reply “no fault found”. Please help. Extremely frustrating.
  • Anonymous Mar 24, 2008
    my p990i touch screen is not working . iam unable to open most of the aplications plz give mea solution
  • Anonymous May 26, 2008
    touch dont work
  • bestjay_13 Jul 16, 2008
    the screen is not working properly the pointer is 2 inches away from the stylus tip. urgent help please... thanks a lot...
  • ravindervirk Oct 12, 2008
    just its lower part working how i 'll calliberate touch screen functions
  • Ahmed Abdelsalam
    Ahmed Abdelsalam Oct 20, 2008
    i have exactly the same problem, and the calibration test gives me too far message for point 1 and it is good for points 2,3,4
  • Anonymous Oct 22, 2008
    touchscreen not functioning in all icon
  • Anonymous Feb 13, 2009
    in my phone (p990i) sony ericssion touch screen problem
  • shechewin Feb 14, 2009
    The screen of my P9901 Sony Ericson Phone cannot work anymore... I didnt use this phone for 7 months, because I got a new phone... and after that, my screen cannot work anymore when I ttried to use it now...
  • sr_20_8 Mar 16, 2009
    how can i fix it, because when i touch number 7 on the screen it will appear number 8.. using the set up wizard i cant tap the center of 1 for calibarting my screen.is there any solutions that can i use such as reprograming my phone to fix the screen?
  • Anonymous Apr 08, 2009
    my touchscreen is not working at all how can i solv this problem
    can it be solved by master reset
    rply soon
    thnks
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Posted on Jan 23, 2008
Go to control panel menu - setup wizard, click yes, and so on until you see 1 2 3 4 numbers blinking.
Posted on Mar 07, 2008
I had the same problem, and it got fix partially after I dragged the stylus on the screen from up the top to the bottom. After that i've touched the four corners of the screen (where the screen is covered by the plastic case). After that i could enter the calibration screen and could touch the 1 2 3 4 buttons. I've done the operation 3 times, the first 2 times without doing the calibration after, and as you can imagine the problem came back after opening and closing the flip for a couple of times. After the calibration the problem did't returned.
Posted on May 20, 2009
5 Suggested Answers
SOURCE:
SOURCE: Touch screen not working properly
you can do it by running setup wizard, located in control panel->others-> setup wizard and follow instructions till you will be asked to tap on blinking points.
Posted on Nov 21, 2007
SOURCE: p990i touch screen problem
ITS AN HARDWARE ISSUE WHICH YOU NEED TO GET FIXED FIXED
Posted on Sep 08, 2007
SOURCE: p990i touch screen calibration lost
me 2
Posted on Aug 20, 2008
SOURCE: P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Posted on Jun 18, 2009
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
My phone Sony Ericsson P990i touch screen is not working corectly
As you said your touch screen doesn't works properly it means that you are able to work with the screen only the response of the touch screen is not so effective.Then you should not worry.You have just re calibrate the phone for more effectiveness.
The steps to recalibrate is quite simple
Go to control panel menu-Setup wizard
tap 'YES' before cancel appears.Do this until you see 1,2,3,4
numbers blinking...
Mostly this will solve the problem.Then you have to see the sensor or the Keypad IC fault.and replace it accordingly...
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Sony Ericsson P990i Cellular Phone
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
Touch screen stopped working
Try calibration! else, the only way is to change it, i did it my self, i think it would not be difficult if you have done similar things! you can buy it for a reasonable price on the net. Good luck
Aug 23, 2008 | Sony Ericsson P990i Cellular Phone
Touch screen is not working properly.To open application i have to click 2 inches above the application icon.
re-calibrate your screen via the setup wizard. if that doesn't work, try installing upgrade software (os) if that doesn't work there is a hardware failure
Jul 30, 2008 | Sony Ericsson P990i Smartphone
Reg Touchscreen
first of all calibrate ur touch
then if not works
please change ur touch pad
Sep 20, 2007 | Sony Ericsson Bluetooth handset pink...
Sep 10, 2007 | Sony Ericsson P990i Cellular Phone
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
Sony Ericsson P990i Cellular Phone Logo
4,987 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
