Question about Motorola Mobility RAZR V3
Motorola v3 cell phone
When i trun on my phone the keys light up but not the screen..How do i fix this problem. My girlfriend had it last and i think it is water damage cause it show's the red dot....What can i do to fix this problem?
  • guillaumeger Nov 07, 2008
    Apparently this seems to be a common problem for Motorola KRZR.
    Sometimes when I remove the battery (it happened quite a few times when I was looking for the MicroSD slot, only to realize I didn't have to remove the battery to put one...), and turn the phone back on, the keyboard lights up but not the screen, but a few seconds later (like 5-10 seconds) the LCD finally turns itself on. And sometimes it just works has excepted.
    Weird, eh?
What worked for me was just to stick it on top of a running dryer. Turn your dryer on, then set your phone right on top of it. The water should clear itself out, it works!!
Posted on Aug 30, 2007
  • 4 Answers
You need keyboard assembly
Posted on Aug 31, 2007
I don't know about the red dot, but my dad had the a similar problem, lit keys and no screen. I just took the battery out and put it back in. That seemed to do the trick. Hope that helps!
    Problem Solver:
  • 5 Answers
You shold replace the flat cable, if you can find one, or buy one.
Posted on Aug 24, 2007
SOURCE:
My Motorola RAZR V3 cell phone key board lights up but not the display screen. How can I fix this?
IS PROBLEM NAME IS STRIP PROBLEM OKK PLZ CHECK THE STIP IS CUT MOBILE DISPLAY NOT WORKING IS PART PRICE IS ONLY150
Aug 29, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My motorola rokr e8 is very unresponsive. when i press the keys to dial a number there is a long delay before it registers on the screen. can u help?
ya...mine does too. the last software fix in Aug was SUPPOSED to fix the issue, but i think it made it worse.....you can try to reset the phone....you just might have too much info on it.
now careful, cause a master reset on this phone, will delete everything on the device, so back everything up first.
go to MENU > SETTINGS > PHONE SETTINGS > RESET > RESET ALL SETTINGS
***default code is by default 000000 (6 zeros)***
good luck :)
Dec 09, 2008 | Motorola Mobility RAZR V3
Motorola v3
you need to hvae the flexcable replaced
Aug 24, 2008 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3
this problem has probably occured due to the phone being knocked. i used to have a motorola l7 slvr and it did exactly the same, i found that if you hit the back of the phone fairly hard the screen would come back on. im not sure if it is the same for the razr but hey its worth a try. ti be honest i think motorola are terrible mobile phone manufacturers but great 2way radio manufacturers
Mar 17, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3 - Key Pad not working
have the flexcable replaced take it to a mobile service center and have them replace it for you.
Sep 14, 2007 | Motorola Mobility RAZR V3
Motorola Razr - Keypad Doesn't Work
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Jun 25, 2007 | Motorola Mobility RAZR V3
Switches on then nothing
i think you screen is jammed.send to fix shop
Jun 18, 2007 | Motorola Mobility RAZR V3
Verizon Motorola Razr V3c
This Is Caused By A Software corruption in the phone's memory chip its a quality defect this will require a service reinstalling the software from a company authorised service center
Apr 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
167 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
