FixYa.com
Tags:
Toshiba SD-5000
It only says loading (by 2 users)
posted by camilion4 on Aug 24, 2007
Itplayed fine for a while now only says loading when I put a dvd in what is wrong? Is there a factory reset?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by jackman6, posted on Jul 12, 2008
The player was fine last evening. Today, just says 'loading' and will not play. I've tried reloading, cleaning the player (my disks are all clean), but still the same. Ready to throw out!!
Solution #1
posted on Feb 09, 2008
Not Rated (0)
stormer2000
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I got the same issue here. I was surprise to find that heating it (near 30 Celcsius) fix the issue.I suspect it misses lubrifiant on the plastic gears.
First thing I noted when I got this DVD is how silent the motor is, but it is probably also very weak.
Regards,
Nicolas
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these DVD Players problems?
Toshiba SD-5000
Loading forever
My player is stuck on loading... Answer This...
Toshiba SD-5000
Disc Tray
Cannot get disc tray to open,... Answer This...
Toshiba SD-5000
Disc Tray will not open even...
Just got this unit, every thing... Answer This...
Toshiba SD-5000
Marcelo Brum
I have one toshiba sd-5000 in... Answer This...
Toshiba SD-5000
Playback won`t start
My Toshiba is only about 7 mos.... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
