Question about HP LaserJet 2420dn Printer
HP LaserJet 2420dn prints twice
Whenever i give a print command the printer prints two copies. At times the whole work of one day is reprinted on the second day
    Scholar:
  • 31 Answers
You may have checked this already, but make sure your printer driver is not set up to print two copies per print job if it is then that's the easiest place to change settings. Or you can print out your printer's menu by doing the following: To print a menu map 1. Press (SELECT button) to open the menus. 2. Use (UP button) or (DOWN button) to scroll to INFORMATION, and then press (SELECT button). 3. Use (UP button) or (DOWN button) to scroll to PRINT MENU MAP, and then press (SELECT button) Look for anything that says "copies" and usually that will let you know what is set on the printer. To change a control-panel setting 1. Press MENU to open the menus. 2. Use (UP button) or (DOWN button) to scroll to the menu that you want, and then press (SELECT button). 3. Some menus might have several submenus. Use (UP button) or (DOWN button) to scroll to the submenu item that you want, and then press (SELECT button). 4. Use (UP button) or (DOWN button) to scroll to the setting, and then press (SELECT button). Some settings change rapidly if (UP button) or (DOWN button) is held down. An asterisk (*) appears next to the selection on the display, indicating that it is now the default. 5. Press MENU to exit the menu Good Luck.
Posted on Aug 24, 2007
SOURCE:
Copying without command
Sir/ Madam
I think You Give Lot Of Print Command And Mistakable Turn Off Your Printer Whats Why Whenever You Turn Your HP Printer Connected With Computer It's Start Copying And Printing By It's Self,So I suggest You To Cancel All Print And Copy Commend By Pressing Cancel Button Or Follow The Step On Below URL Link:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5071505&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c02476541-10%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Or
Follow Us For Hear For HP Printer Support
Jan 08, 2014 | 2SToner HP Laserjet Pro M1213nf Printer...
How to print middle page from scanned document
Dear! First of all, You should check your printer timer may be it enable and after the completing the time it shutdown automatically. Secondly, You choose custom option and use it command it from 85 to 100 and 30 copies for each it will work completely.
Thank You
Jul 25, 2009 | Ricoh Aficio AP410N Laser Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
CAN'T PRINT A "REPRINT.......ANY RECEIPT"
You're welcome. Please come back and give this answer a rating of fixya. Good day :c)
Feb 16, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Kyocera Mita FS 1010 every few days it prints out all the pages
Format the harddrive, or go to the properties and change the setting that says leave copy on the harddrive, if all this not working try to initialize the memory and you will be fine.
double check on the driver properties check if it says direct printing or it keeps any copy on the machine.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 13, 2009 | Kyocera Mita FS 1010 Laser Printer
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Reprint
yes, if your model has a harddrive...
as far as i know your printer should have command tools on a cd... install that software, add your printer there and search in the drivers panel "print & hold" option and check that option!
Jan 29, 2008 | Konica Minolta bizhub C250 All-In-One...
HP LaserJet 2420dn Printer Logo
436 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
