SOURCE: where is the o2 sensor located on a 1991 honda accord ex 2.2 engine
Further clarification on the O2 sensor location: It is in the exhaust pipe, under the center of the car, on top of the pipe, just aft of the oil filter.
SOURCE: 1991 HONDA ACCORD EX STARTER MOTOR WHERE IS IT LOCATED?
MOST HONDA STARTERS ARE AT TOP OF TRANS MISSION BACK SIDE HOPE THIS HELPS UNDER HOOD
SOURCE: ac compressor clutch relay 1991 honda accord
Difficult to describe, but I will give it a try.
Inside the driver's side fender, close to the front of the car, there is a bracket that is held in place by one bolt, but which has a short horizontal bar as part of it which has two large clips encircling two cylinderical devices which have wires clipped into them at the bottoms. The one closest to the front (radiator) is the compressor clutch relay. The other one is the condenser fan relay.
Hope this helps you find it.
SOURCE: blower motor 1991 honda accord ex
the blower motor is located behind and under the glove box. its held to the blower housing by three screws. remove the three screws and the motor will slide down and towards you. to test the motor. apply power to the yelllow/black wire and ground to the blue/red wire. the motor should run. if not you prob have a faulty power resistor.
