Question about Bissell 1720-1 Little Green Wet/Dry Vacuum
Won't spray water to clean rug
Not sure which side to put the cleaning fluid in and water won't spray out
  • Anonymous Nov 13, 2007
    manual
Push in on the front of the water supply tank while holding down the trigger
Posted on Jan 12, 2008
SOURCE:
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
The water or solution will not shoot out
Good Afternoon! This is a wonderful machine! Unfortunately, the pumps tend to go out. The pump not only releases the hot water to spray, it also controls the release of the cleaning fluid. Most likely you will need to replace the pump. There is an 800 number on the back at it's base. Serial and model numbers as well. You can test the unit to make sure this is the problem. Fill both the bladder and cleaning fluid resevoir and plug the unit in. Turn it on, release the handle and lower the handle to the floor while it's running. It is safe to do this and the brushes will stop rotating. You will see a hole (opening) in which the fluids normally flow. This hole SHOULD have suction when placing an object directly over the hole. Fingers flattened, a paper plate, anything that is twice the size of the opening and solid enough that it can not be sucked into the unit. If there IS suction, next test is to return the handle to the upright position till it clicks in place. Turn the knob selection from floor to tools. Squeeze the fluid release lever while aiming at a paper plate. See if it has sprayed fluid, then release the handle and try sucking up the fluid. If you again have no fluids released, you do need a pump. Check the age of the unit. Bissell has a 2 year Warrantee that usually covers most repairs and the 800 number will give you local repair shops. If you are out of warrantee, the pump can be ordered and installed through Sears for a reasonable price. Once you do this, YES, purchase their extended warrantee, it always pays off because the pumps go out a lot. But hey...they do a beautiful job cleaning! I hope this is helpful. By the way, if it doesn't pick up fluids, be sure to clean the unit thourally. Take pictures on a cell phone to double check how to put the parts back if you're afraid you won't remember OK?
Sep 22, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
On a Royal #CE6600 it will not spray water on rug,
spray opening may need cleaning (small wire may work)
Aug 31, 2009 | Vacuums
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 1720-1 Little Green Wet/Dry Vacuum Logo
416 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
