Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
XP Themes I installed these themes. but when you try to use them only the background and cursers change. all the tool bars and skins change back to windows classic style. all the windows visual style files are in WINDOWS, RESOURCES, THEMES and in the theme folder. Any ideas???????please help
  • Tom Morris Aug 24, 2007
    for example there is a folder named Tribute inside there are the folders Font, Screenshots, Wallpaper, Icons, Shell( normal colour, shellstyle.Dll), and a windows visual style file named tribute. outside the folder is the windows theme file named tribute.on right click properties themes on the desktop it comes up with the theme Tribute but on the preview pic it only shows the out line of the skin infront of the background. under apperence, colour scheme it has the name Tribute, but the box under Windows and Buttons is blank.
  • som_baby Oct 16, 2008
I wanna full version themes for my desktops
Posted on Sep 20, 2008
Yes u can uni install the software and shut down ur system and restart.and again try to install.
Posted on Mar 15, 2009
Nice one
Posted on Dec 21, 2008
Good one
Posted on Aug 12, 2008
Im new at this, so can you please tell me how to download .zip?
Posted on Jun 11, 2008
Cgghdf nfgcghfdghfghfb
Posted on Feb 12, 2008
  • 55 Answers
I have had permission from original copy. Before starting, make sure you have enabled XP to show *all* system folders and hidden files. Also, I have yet to come across a downloadable Style XP theme that wasn't in a ".zip" file, so the following directions deal only with ".zip" files. These directions are pretty detailed, so you need to read them carefully. It's not as difficult as it sounds, I promise! 1. Download ".zip" file - remember what folder you downloaded it in. I usually use the "My Documents" folder on the desktop because it's easy to remember. 2. Locate the downloaded ".zip." 3. Once you have located the .zip file: a. For XP users using the Windows XP built-in zip file manager: locate the ".zip" FOLDER (not file), and then open it as you would any other folder. That will open the folder and show you the compressed files. Click on "file" on the toolbar, then "extract all" and then extract the files to "c:/windows/resources/themes." b. For XP users using WinZip or another compression program: click on the .zip file, and extract to "c:windows esources hemes." 4. After you have finished extracting the files, right click on your desktop then click on "properties." That will open the Display Properties dialog box. Then: a. For themes with the ".msstyles" file extension: click on the "Appearance" tab then choose your desired theme from the "Windows and buttons" dialog box, then choose which color scheme you prefer from the "color scheme" dialog box (most themes only come with one color, but some come with more) (see screenshot1). Click "apply" then close the display properties dialog box. b. For themes with the ".theme" file extension, make sure the open "display properties" window is the "Themes" tab (it's the default window, so you should already be looking right at it.) Choose your theme from the "themes" dialog box (see screenshot2). ".Theme" files often come with icons and wallpaper, but it is not required that you use the icons or wallpaper, so before you click "apply" make sure the wallpaper and icons are the ones you want - for wallpaper click on the "desktop" tab, then choose your wallpaper. For icons, same as the wallpaper, except click on "customize desktop" and then choose your icons (see screenshot3). Once that is accomplished, click "apply" then close the display properties dialog box. c. For themes with both the ".msstyles" and ".theme" extensions, use the ".theme" version if you want to use any included icons, wallpaper, etc. Use the ".msstyles" version to use the "visual style" only without using any of the included icons, wallpaper, etc. You're done! Yeah, right, wouldn't that be nice? You only *wish* it was that easy, because I know I do. So keep reading. There are certain things that *must* be in place in order for themes to work correctly, so I recommend you double check to make sure everything is good to go before you do any of the above. So go ahead and open the "c:/windows/resources/themes" folder, and follow the below directions: 1. ".Theme" files *must* be directly within the "c:/windows/resources/themes" folder (see screenshot4), and not within individual folders. a. If you find any in individual sub-folders, simply move the *.theme* file directly to the "c:/windows/resources/themes" folder. 2. ".Msstyles" files *must* be within their own individual sub-folders within the "c:/windows/resources/themes" folder (see screenshot5). For example, the file "generic.msstyles" must be in a sub-folder entitled "generic," "generic1.msstyles" must be in a sub-folder entitled "generic1," etc. a. If any ".msstyles" files are directly in the "c:/windows/resources/themes" folder, make a *new* sub-folder and name it EXACTLY AS THE ".msstyles" FILE IS NAMED (minus the ".msstyles" extension of course), then move the ".msstyles" file into that sub-folder. 3. After doing the above, you will need to check each individual sub-folder within the "c:/windows/resources/themes" folder, *including* the ones you didn't have to fix, or create yourself. Why? Because: a. It is essential that the name of the sub-folder match the name of the ".msstyles" file exactly, and caps, lower case, spaces, underscores, etc., ALL count - i.e., the file "generic.msstyles" must be in a folder entitled "generic," "Generic_01.msstyles" must be in a folder entitled "Generic_01," etc. (see screenshot5, above). If they don't match, you will need to rename the sub-folder that the ".msstyles" file is in so that it matches the file name. b. Some ".zip" files will extract files into what I call a "sub-sub folder." For example, the file "generic.msstyles" might be in a sub-folder of a sub-folder; i.e., "c:/windows/resources/themes/generic/generic." If this is the case, you will need to move the ".msstyles" file into the first sub-folder, "c:/windows/resources/themes/generic." Delete the "sub-sub" folder after you've moved the ".msstyles" file. 4. Some ".msstyles" themes include what is known as a "shellstyle" ("shellstyle.dll".) "Shellstyle.dll" should be in its own sub-folder entitled "shell" *within* the ".msstyles" theme sub-folder, "c:/windows/resources/themes/generic/shell" (see screenshot6). Sometimes, the "shell" sub-folder has its own sub-folders, for example, "c:/windows/resources/themes/generic/shell/normalcolor" (see screenshot7). If this is the case, "shellstyle.dll" should be in the "normalcolor" sub-folder (see screenshot8). If you find any "shellstyle.dll" files floating around in the "generic" sub-folder itself, make a new sub-folder, name it "shell" then move "shellstyle.dll" into that folder. Okay, NOW you're done. Have fun with your new theme! From ""
Posted on Aug 24, 2007
How to install themes on motorazr v3i?
you may have downloaded anything, but not themes.. becoz there are no themes for our phone. u can change appearence by changing skins, go to this page and install skins V3I SKINS
Jun 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How to install a themes or skin for motorola RAZR v3x???
IF YOU WANT TO INSTALL SKINS/THEMES on your phone. Get Skin Manager v.0.51..
you need skin manager v0.51 also the driver for motorola. downloads themes then extract it. open skin manager wait until it reads your fone then choose menu files,
if downloads button is clickable
click it choose the extracted skin just click the file you will see specially the .SKI
then go to SKIN on upper left corner
look for install dont check anything
look for the file on your skin extracted file then install it.
wallahhhh installed
after it click "more" button on lower right then click restart phone
make sure the skin is compatible to your UNIT or model of fone. good luck...
Feb 20, 2009 | Motorola Mobility RAZR V3x Cellular Phone
can you tell me how format motorola rezer v3i mobile
tell me useing which software
Oct 01, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to install a themes for my motorola L7
u can use
P2K tools to install moto skins
It is available @ for free
Jun 09, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How to add themes and skins
you can doed with the midway
Apr 12, 2008 | Motorola Mobility RAZR V3
Problems with Themes Downloaded from MediaNET
go to your download folder and select you themes and install them
Mar 24, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Instolation of themes...
i don't think ther are themes for v3i....
but i can tel u about skins....
atleast u can change the look using themes.....
my email id is
if anyone wants help with v3i skins just mail me and i'l mail u a solution...
btw to do all that u need "SkiMan"
thats the motorola skin manager... or try P2k tools/ P2k Manager...
best solution for all problems regarding motorola phones visit
if my help was helpful dont 4gt 2 thank me....
Dec 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola v3x themes
pls help me how to install themes to my razr v3x..
Sep 12, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Themes continued..
Download and use a program called styleXP from here, it's your last solution :
Aug 24, 2007 | Microsoft Windows XP Professional With...
Download themes/skin
here is the link where you can find all information to install themes on motorola download various themes from link below for motorola
Aug 17, 2007 | Motorola Mobility RAZR V3
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
931 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
