Epic 400 Mx Treadmill Logo
orlando Posted on Jun 29, 2013
Treadmill Sticks Please tell me how to fix a treadmill I purchased that is increasingly sticking and is no longer safe to run on.
1 Related Answer
Anonymous
  • 218 Answers
  • Posted on Aug 13, 2010
SOURCE: treadmill sticks on my Epic Treadmill
replace the drive belt
1helpful
I need to purchase a replacement safety key for my pink confidence fitness treadmill and cannot find where to purchase in Australia. Need help
http://www.lifespanfitness.com.au/Treadmill-Safety-Key
just measure the diameter of the socket on treadmill and order a magnetic safety treadmill key.
Can get them on ebay but you would need to check the diameter of the sold key matches by contacting seller via ebay messaging.
this one below is from singapore $1.49 cost
http://www.ebay.com.au/itm/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock-New/172841698326?epid=2210203347&hash=item283e2b0416:g:wmIAAOSwRLlZo~B-
this one below is from australia
https://www.ebay.com.au/p/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock/26003745571?iid=282454053275&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140106155344%26meid%3D255259a17a4f4034bdd90d3236d772e0%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D192235118553%26itm%3D282454053275&_trksid=p2047675.c100005.m1851
Lifefitness treadmill belt sticks even though wax bag is full
It may not be sticking, but instead slipping on the front roller. You can resolve this by simply tightening the running belt. This adjustment will be done by using the rear roller.
2answers
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
28helpful
I have a pro form treadmill and it seems like the belt is sticking, its about 14 yrs old. I think I might need to replace the belt
kilgore511,
The most common cause of belt sticking or "slippage" is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
If you have found this helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
The treadmill seems to work fine at first then the belt kinda sticks. It like stops and goes. Electrical seems fine
It's possible that your treadbelt needs lubrication, or simply adjusting. Here is a tutorial on adjusting your treadbelt:
Here is one link to purchase a lube kit, there are probably many others online also:
Should you actually need to purchase a new treadbelt, I would try to identify which specific model of the Proform 530 you have from this list and then in the parts list for that treadmill scroll down to "Treadbelt"
Got a 390pi proform and when I step on the
Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lifting one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck.
1helpful
Belt sticks on one side while running
There are hex bolts on the bottom rear of both sides of your treadmill. Turn one side one direction and the other sides the other direction until the belt tracks in the middle of the platform.
2answers
Thumping noise that increases with speed
OPEN MOTOR SHROUD SO YOU CAN BETTER INSPECT THE UNIT CHECK THE DRIVE BELT THEN I WOULD CHECK THE RUNNING BELT TO SEE IF THEIR IS ANY DEBRIS THAT THE BELT ITSELF IS SPLITTING SINCE YOUR SAY A THUMPING SOUND. SINCE KEYS FITNESS MADE THIS UNIT THEY ARE NO LONGER IN BUSINESS, BUT TREADMILL DOCTOR HAD PURCHASED THE PARTS. SO GO TO TREADMILL DOCTOR.COM THEY MAY HAVE THE PARTS YOU NEED
1helpful
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
