Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Help with my double vision
My projection television seems to have a "double vision" in the picture. I have cleaned the lense covers, but what more do I need to look into? The picture seems to overlap making it very difficult to read words on the screen. Help....Thanks,
  • turbo7979 Aug 25, 2007
    I have had a few people tell me that it is a "conversion" problem. The set is probably about 20 years old; model #VS458R and they are saying it will cost about $250. I'm not sure if the set is worth fixing at that amount. Neil
  • 55 Answers
What model is your tv? Panasonics have a 'self-alignment' system in the menu, or a manual alignment that the menu will actually walk you through. Other System's will be able to do that also, such as Hitachi.
Posted on Aug 24, 2007
SOURCE:
Double vision picture picture is hazy
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 06, 2010 | RCA P55000 55" Rear Projection Television
My Hitachi TV is showing a double vision on the lefthand side of the screen.
Your projection lenses are probably covered in dust. My TV did the same thing with the blue color on the right side. Usually you can get to the projectors from the bottom front or back. Goo luck.
Mar 10, 2010 | Hitachi Televison & Video
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
Mar 08, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture Problem!! and its not convergence (Double vision except for middle of screen)
Could be pin correction circuit or your picture tubes could be worn out . Sometimes when the crt's get weak the edges seem not as clear as the center of the screen . Give model number if you think the pin correction may be your problem but, the tv is pretty old and avg. life for them is 12 to 15 years when the picture tubes start to degrade . Good luck
Mar 01, 2008 | Sony KP-61S65 61" Rear Projection...
Double vision
The double vision is from bad convergance ic's and posibly some support resistors or pico fuses. if you are not an electronics tech I suggest to have one do it. the ICs can range from $45.00 to $60.00 each and is suggested to replace both of them. some mitsies had one IC which I cant remember how much it was. tech charges vary. some prices may be $150.00 to $300.00 shop around.
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
Yellow at the top, double vision, blurr
Good Day, turott1;
You need repair in the convergence circuit, purchase KIT 10. You can buy this at B&D ENTERPRISES, at 1-800-458-6053.
Good Luck, big IRISH.
Dec 30, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Double vision
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2007 | Toshiba 50A61 50" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
