Question about NorStar T7316E Corded Phone
System startup when on a call the phone will go dead and all the lines will start to blink within one minute the lines are back up and the display shows system startup
  • 201 Answers
Sounds like the power is going off and on in your system or phone. The blinking lights are a boot up sequence. If this happens on just one phone, try changing the line cord, try swapping phones to see if the problem follows a phone or stays at the port. If all phones do this at the same time.... Make sure the power cord is plugged in tightly on your main control unit, maybe change the outlet the system is plugged into. You could also get a UPS battery backup power for a computer and use that to help resolve this problem AND keep your system up and running for short periods in a power outage. If it is not a power issue, there may be a serious problem with your main control unit and you should get a local technician to look at it. If this is a rare occurrence it will be harder to locate.
Posted on Aug 24, 2007
My hp 17 inch m7 k211 dx will not turn on the power port light blinks 3 times. Help?
HP ENVY m7-k211dx Notebook PC?
those are called BIOS blink code errors.
take the battery out yet and try, batteries love to dye and short.
run on line AC power only that cure it?
only 1 year old , (or less) 1 is max. Aug 1015 RTM
the books on it are here.
with battery out, will the display even show BIOS messeages
see page 84 in the manual.
see this, ? quote:
To start Setup Utility (BIOS), follow these steps:
Turn on or restart the computer, and then press
esc while the "Press the ESC key for Startup Menu"
message is displayed at the bottom of the screen.
2. Press f10 to enter Setup Utility (BIOS)
page 86 shows how to run BIOS base line Diagnostics.
that be next
page 4 in the service manual tells you the power light blink rules.
the lightening bolt LED binks , means no line power, and battery is now dead. is the power pack missing>? unpluged.
try a direct on connection to wall AC power known good?
the same light blinks i SLEEP mode.,
here is HP;s offical blinking (LED) lamp codes and cures.
Apr 04, 2017 | HP Computers & Internet
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
Oct 26, 2012 | NorStar Meridian M7310 Phone
I have a brother 680 Fax macine I get a dial tone...I dial, it rings when I press start button- it won't fax - It says "Transission Error"-what I am doing...
Is the phone line plugged into the LINE jack? If it was accidentally plugged into the EXT jack (for extension phone), it will allow you to hear the dial tone and dial, but as soon as you press Start, it cuts off the extension phone, which, in this case, would be the phone line. Your call goes dead, and you get an error.
I hope it's that simple. If the line is already in the LINE jack and you have this problem, it's serious. Probably needs a new main board.
But you can try wiping out all the memory, just in case it's a temporary glitch causing the problem. Here's how:
Get into Maintenance Mode by pressing
Black Start
The display should read MAINTENANCE, and all the lights should be blinking in unison. If not, touch Stop and try it again. It will beep at you as if you're making a mistake; ignore the beeps and plow through without waiting to see what the display says.
Once in Maintenance Mode, press the numbers 91 on the dialing pad. Sit back for a few seconds while the machine initializes everything in its memory, except the phone numbers stored in it. When the display is back to MAINTENANCE, press 99 to exit Maintenance Mode. The machine will go through it's startup procedure, as if you just plugged it in.
Try sending a fax. If nothing has changed, try the memory clear procedure again, except instead of touching 91, try 01. That clears everything back to the state it was in when you first pulled it out of the box. You'll have to re-enter the date & time and your phone numbers.
Mar 11, 2011 | Brother MFC 420CN All-In-One InkJet...
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
My nokia 7710 not start when start display nokia and screen blink and again resatard and display nokia and blink pl solve my problem
try to format use this way
Switch-off your phone.
1. Press and hold these 3 keys; (check in pic) on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Sep 30, 2009 | Nokia 7710 Cellular Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
Easynote R4 no screen visible and nothing from an external monitor either.
graphics chip blown.
are you getting any lights flash at startup, or any beeps for the bios errors ?
Mike @ compurepair.
Apr 04, 2008 | Intel Celeron -D 2.26Ghz Computer System...
NorStar T7316E Corded Phone Logo
129 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
