SOURCE: how many spark plugs does my 1996 pontiac transport need
Or you can get the Bosch dual sparks and don't have to wory about the gap.
SOURCE: location of horn on the 1996 pontiac transport
CHECK THE WHEEL WELL.IM NOT SURE LEFT OR RIGHT SIDE.
SOURCE: Where is the ECM on Pontiac Transport 95
The computer should be located behind the front passenger side kick panel by the right foot under the dash.
SOURCE: 1998 Pontiac transport van wont start:
Well you hit all the major ones, could be crank position sensor, ignition module, a bad coil pack (it should have 3), you need to check that you have spark to each plug while the engine is turning over (!!!be careful as this will hurt if you get shocked!!!), this will rule out coil packs. if you have no spark to any plug your looking at a bad ingnition module (which is what the coil packs bolt to). Hope this gets you on the right track!
SOURCE: How do you change a fuel pump on a 1996 Pontiac
You have to drop the fuel tank and the fuel pump will be located at the top of the fuel tank usually four bolts holding the pump in the tank be careful as fuel vapors are ignitable...
Testimonial: "Thanks: I thought so but was hoping there was an access panel from above."
