Question about Danby 22 in. DDW396 Free-standing Dishwasher
Danby DDW396W won't drain
The dishwasher seems to be missing its drain cycle. When it finishes the wash cycle, instead of the water gushing out into the sink, nothing happens at all. The water stays in the bottom of the washer. I've unscrewed the hoses and they are not blocked or anything, so the problem is in the machine itself.
  • 6 more comments
  • Anonymous Dec 13, 2007
    I have the same problem, the machine makes a noise like its struggling when it's time to drain the water but it won't drain.  Turning machine off for a couple of minutes, and then switching cycles usually gets it to drain.
  • jrcmr Jan 24, 2008
    I am also having this problem, except switching cycles doesn't seem to get it to drain, I have verified that it's not the tubing as I can blow down it get bubbles, but it just won't drain.
  • melcurlysue Nov 01, 2008
    I have the same problem. The water wouldn't drain out and you could hear the switch clicking but the pump wouldn't turn on. Moving the wheel helped free it up but then it got stuck again half a day later. Took it apart to clean it and put it back together. I believe I need a new pump but having a hard time finding it as the part/dishwasher seems to have been discontinued. If anyone knows where to order/find one, let me know!
  • pklemmensen Dec 23, 2008
    I have the same problem but this started about a week ago, I not sure what can be done about it. If some one could help that would be great..
  • Anonymous Mar 04, 2009
    Same here.
  • kurtisdigita May 11, 2009
    I had the same problem with the dishwasher not draining. I could hear a buzzing sound, which turned out to be the pump motor (left side of the unit) trying to run, but unable to start. When I took the unit apart, I found that I just had to twist the motor fan to free it, and it ran again.
    However, I did not want this to keep happening, so I took the pump housing off, as well as the rear bushing mount, and lubricated both motor bushings with an anti-seize lubricant I have, and the motor runs VERY well now.
  • Shane Copland
    Shane Copland Feb 13, 2019
    How did you take the unit apart?
  • Shane Copland
    Shane Copland Feb 24, 2019
    So. I replaced the water pump with a new one from Repair Clinic. My unit seems to be draining but now there is a high pitched buzzing. Is this what it is supposed to sound like?
If you remove the cover, you will discover that there are two motors inside. The larger one on the right runs to fill the machine and spray the water during washing. The smaller one on the left drains it. Oiling this motor, or manually actuating it by spinning the wheel between cycles may solve your problem.
Posted on Jan 26, 2008
Open the dishwasher, remove dishes and dishrack. Remove the cleanable filter on the bottom. Get your hand down in the drain area (which is submerged in water at this point) and feel around the inside edge. Towards the front right you will feel the exit point for the drain, which is a small hole with plastic grate kind of feel, this is probably clogged up with stuff. Clean that off (I've sometimes had to use a fork to pry bits of gunk out of the grate.) Even when it's clean it won't start draining because it is a mechanical system that only opens during the drain phase of a cycle. So close the front, attach the hose to the faucet and start a cycle. If you successfully cleared up the clog then it should drain. Once I have it draining I usually push it forward through a couple of cycle changes so it drains and refills and drains a few times. Then I put the filter back on, the rack back in, load it up with dishes and get back to washing.
    New Friend:
I had the same problem, i oiled the motor on the pump and thought i had fixed it because it started working. got it all back together and it didnt work. so opened it up again and found that on the bottom of the dishwasher there is a spade connection for the heat element. it has two white wires attached to it and it is one side of the heat element im thinking its like the neutral side but aparently there is enough current going through it because it had gotton hot and the wires were barely connected. went to hardware and bought a new connector, make sure it is a hardened one not the cheepy ones, remade the connections and it has worked fine sence.
Posted on Sep 27, 2012
  • bob06254
    bob06254 Sep 27, 2012
    forgot to add that one of the white wires goes to the pump so it was loosing contact.
    New Friend:
Simple repair. Remove cover screws front, sides and back, lift off cover, little motor on left side, give the plastic wheel a spin with your fingers and oil it. If the motor isn't burned out, it will work. Diagrams Sears are handy to see how everything comes apart. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=DDW396W
Posted on Mar 19, 2011
    New Friend:
Question is, how do you get to them to oil them? The back, the fron, the inside???? Help please
Posted on Jun 27, 2010
    Problem Solver:
  • 4 Answers
Use this guy's method kurtisdigita.
Thank you so sooooo very much. IT WORKED !!!!!!!!
Just oil the left one.Perfect.alot of screws and watch out for the raw metal(cut my hands to shreds) but,it works and i look like the husband i want to be.
Posted on May 25, 2009
6ya staff
SOURCE:
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Danby dishwasher pump
An appliance parts supplier might be able to cross reference your pump to an equivalent.
Mar 12, 2014 | Dishwashers
Danby dishwasher seems to be leaking on front left side - how to fix
http://www.retrevo.com/support/Danby-DDW396W-Dishwashers-manual/id/886dj685/t/2/
Above is a user manual, below is a self help dishwasher repair how to.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
You really must get a service manual. But if you cannot find one, simply open up the inspection hatch, and look for the source of the leak, usually around the Pump, filters etc, often a fitting has come loose... as related locate and repair your leak.
Jul 12, 2010 | Danby 22 in. DDW396 Free-standing...
Danby countertop dishwasher DDW396W pump size???????????
Best place for Danby parts is Sears Parts department online. Type in your model number DDW396W. They have diagrams and assessable and parts for just about everything you need.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=DDW396W&pop=flush
Just click on the sub components area that you need!
-Dustin
Jun 25, 2009 | Danby 22 in. DDW396 Free-standing...
Will not drain the water out.Between cycles or at the end
This might be to simple but if the pump seems to run then check the tubes for any way that it might be blocked bends, blocks, ect. If the pump is not running, check out Sears Parts Online. They have just about every part for Danby. Put in your model number and choose a sub component with what you need.
Good Luck!
-Dustin
May 25, 2009 | Danby 22 in. DDW396 Free-standing...
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Danby 22 in. DDW396 Free-standing Dishwasher Logo
3,957 people viewed this question
Top Danby Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Brian Acker
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
