Question about Epson Stylus Photo 825 InkJet Printer
Epson Photo Stylus 825 printer problem
Recently it has started leaving ink smudges on the printouts. It seems that one of the small rollers has picked up some ink and while I have cleaned it the ink shows up again. In the past day or two it's been leaving a spot of ink off to the right of where the ink head has stopped moving. I know that on the canon there are sponges that need to be replaced periodically but not sure if that design is used on the Epson. I have cleaned the heads but no luck.
  • 29 Answers
Depening on the age and usage of the printer, it may indeed be correct that the 'sponges' that collect ink are saturated. Unfortunately, there can only be replaced by a servicer. I assume that your printer is now out of warranty, so it would be better to replace the unit now. The best replacement is the Stylus Photo R380 - it's $109.99 with instant rebate.
Posted on Sep 09, 2007
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
When i print, there are horizontal lines across the page
Have you really recently run the cleaning utility a couple times? If so,it leaves black ink on the rollers that pull the paper through the printer.You can use a Q-Tip (or 3) and rubbing alcohol to clean the ink off.
Bob
Aug 09, 2010 | Epson Stylus 1400 InkJet Photo Printer
How do I replace the old cartidges with new ones?
Did you try the link below? http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=14410&prodoid=22708394&foid=32288&cat=30937&subcat=30940
Good Luck....... Epson Stylus Photo 825 Support Linksrightmenudottedline.gif Epson Stylus Photo 825 Support rightmenudottedline.gif Drivers & Downloads rightmenudottedline.gif FAQs for this Product rightmenudottedline.gif Troubleshooting Guide rightmenudottedline.gif Documents & Manuals rightmenudottedline.gif MSDS rightmenudottedline.gif Contact Support rightmenudottedline.gif Quick Linksrightmenudottedline.gif More on this Product rightmenudottedline.gif Register Your Product rightmenudottedline.gif Buy Ink for this Product rightmenudottedline.gif Epson Recycling Program rightmenudottedline.gif sp825_80x80.jpg Selected FAQ
function setViewedFAQCookie(oid, foid) { var viewedCookie = "EP_viewed_faqs" + oid; var viewed = cookie.Get(viewedCookie); var viewedS = new String((viewed == 'null') ? '' : viewed); var found = viewedS.indexOf("" + foid); if ( found == -1 ) { var newViewed = foid + ((viewedS == '') ? '' : (":" + viewedS)); cookie.Set(viewedCookie, newViewed, null, "/", ""); } } Q: Where can I find the printer manual? A: Your printer software CD-ROM includes an electronic Reference Guide for your printer. The manual is in HTML format, so you need a browser such as Internet Explorer 4.0 or later or Netscape Navigator 3.0 or later to view it. If you are using a different browser, the pages may not display correctly. (A browser is not included on the printer software CD-ROM.) setViewedFAQCookie(14410, 32288);
Nov 04, 2009 | Epson Stylus Photo 825 InkJet Printer
Rows of black ink blotches on my printouts
Found bits of dust adherent to printer heads, took awhile to clean out with fine forceps, but seems fine now
May 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Ink marks on printouts
more than probably you had stranger objects there like piece of paper etc
Jan 15, 2008 | Epson Stylus Photo 950 InkJet Printer
Probelms printing with black ink
On my system when I select print I can go to the print settings and I have the option of selecting either color or black. Not sure if that helps.
Feb 04, 2007 | Epson Stylus Photo 825 InkJet Printer
Epson Stylus Photo 825 InkJet Printer Logo
200 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
