Question about BenQ PB6100 Multimedia Projector
BenQ PB6100 Component input problem
I recently bought a BenQ PB6100 used off of flea bay. When I plugged in the projector to my up converting Philips DVD player it could not find it using the component input and just kept searching. It found it using the RCA video plug and S-video cable but I need the component input for my computer which did not work either. I had two cables so I tried them both for the sake of eliminating the possiblity of a bad cable. Any suggestions? Am I missing something?
  • ReggieD Nov 21, 2007
    I'm amazed that I have this same projector (for 3 years) and that same DVD player (just bought yesterday) and have this very same connection issue. I am at my wits end because I bought $80 worth of cables and the unit still doesn't work when I try to use the High Def aspect but works fine with the supplied RCA analog cables. I guess it does pay to search the internet to see if others are also having the same issues and to find out what their solutions are. Thank you!
You can get high defintion by connecting a cable that is component video source on one end your (dvd) and VGA (to projector)on the other. This cable is available from cables to go.
Posted on Sep 25, 2007
SOURCE:
How do I connect my Benq-mp610 projector (without HDMI) to my ps3
hi,
u can convert the vga input of ur projector to component video input, and u can connect ur ps3's component video to the projector. component video to vga convection cables are available.
ok
Dec 27, 2010 | BenQ MP610 Multimedia Projector
How many cords are needed to connect the pb6100 to my laptop?
Just one VGA cord will do,cause it only has one input for a Laptop or PC.Check your manual if you have one or go to this link-www.about projectors.com/pdf/benq-pb6100-manual.pdf.
Oct 29, 2010 | BenQ PB6100 Multimedia Projector
No Picture
Ok. It still might be the bulb, if not make sure it is plugged in to a working outlet. Also, if that doesn't work unplug, wait 1 hour, push the power button (with it unplugged) then plug it back in. If nothing fixes your problem, it is the power supply.
May 24, 2009 | BenQ PB6100 Multimedia Projector
My Benq pb6100 projector needs a ''shake'' on switching on to run
Hi I am Vortash possibly a loose plug or the bulb housing is not secure and the cut off switch is not contacting .. loose fuse .. dry joints o loose component .. one thing is for sure keep shaking it
and your going to kill your bulb ?. During the arc on the lamp it builds up carbon deposits if they break loose they get hot in the bulb under working conditions against the glass and sometimes fracture it ?. don't shake your your unit unless you can afford to replace this at between $400 and $800 i bet that repair would be a more economic solution hope this helps Regards Vortash
Apr 10, 2009 | BenQ PB6100 Multimedia Projector
Can't access Menu
I have the same problem, any ideas to solve.Thankyou
Feb 22, 2009 | BenQ PB6100 Multimedia Projector
How to hook up BenQ PB6100 Digital Projector to a lap top?
Use a standard "video cable" that is used to connect a desktop to a monitor. Your lap-top will also have a similar video out - this is a blue colored outlet jack on your ap-top with three rows of 5-pin holes. The BenQ also has a similar blue receptor jack almost next to the place where you plug in the mains power cable on the rear of the unit.
Dec 20, 2008 | BenQ PB6100 Multimedia Projector
Pb6100
I think the problem has to do with the videochip component. Perhaps it went misconfigures and need to be flashed. Iwouldn't know how to do this, though.
In any case the problem has nothing to do with your motherboard, because this symthom points to internal problems rather than PC gear hardware.
Aug 16, 2008 | BenQ PB6100 Multimedia Projector
BenQ 8700 projector solution
Hi Rick
The upgrade is the same one used for the BenQ PE8720
Whoever told you this obviously did'nt know this.
You'll be needing Flashloader and the RS232 cable that came with the Projector.
It is absolutely cheeky of them to suggest that you should just use the Component input for all your applications on this Projector.
Make sure they understand that this was a top of the range Projector when you bought it and that it is not a good enough answer.
Apr 02, 2008 | BenQ PE8700 Multimedia Projector
Benq pb 6100 projection from left rear of room
Hi there
This is unfortunatelly not possible at all on the PB Series Projectors. I'm a ASP Technician for BenQ Projectors and know then like the palm of my hand.
Mar 30, 2008 | BenQ PB6100 Multimedia Projector
Super video and composite wont work with progressive dvd
Hi there
Right next to the Mainboard sits the inputboard where all your video inputs go into. This small board might need replacement.
Very cheap to have replaced.
Mar 10, 2007 | BenQ PB6100 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
214 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
