Question about Konica Minolta Konica/Minolta Dimage Dual IV Film Scanner
Dimage scan dual iv
I was scanning color negatives with my dimage and one of my negative strips was too long for the negative holder. It kept the end of the holder open a little. The batch scan did not finish and the holder remained in the scanner. I naivly pulled out the holder when I could not get it to eject by pushing buttons and now the scanner will not reset. I shut everything down and restarted and the green power button just blinks. Any suggestions?
  • gillansmith Aug 27, 2007
    Noa,
    I don't know if you got my first reply to your comments, if so disregard this one. I tried to attach a picture but the file was too large and it seems to have erased my first reply. I will do the picture later. Thanks for your first idea. Unfortunately, no go. I went step by step and when I turned the power on the negative holder ejected like I thought it should. But then when I removed it and closed the door the power light started blinking (like before) when I opened the door and tried to insert the negative holder the machine rejected it like before. With the door open the power light was steady (like before).
    Also, my apologies for not quite getting the idea of the dialogue here. Thanks for you patience. I think I get it now.
    Gillan
    Novelist:
    Scholar:
  • 114 Answers
It's possible you have physically damaged it but not certain. One old engineers trick to reset anything microchip based is to unplug the device, both power and connection cable, and hold down the power/on button for 30 seconds (time it as it seems to take forever when you are waiting) this will discharge any static and reset the chip-set to defaults. With that done completely reinsert reinsert the negative tray/holder *before* reconnecting power and test it. No guaranties at this point but defiantly the place to start. Message back if this is no help.
Posted on Aug 26, 2007
  • Nicholas Wilson
    Nicholas Wilson Aug 27, 2007
    You're image scanner can be thought of as having 2 main components:
    1: the scanner itself and 2: the DiMAGE Master software on your computer. If you are using a Windows PC just make sure you have shutdown and restarted your computer, however if you're using a Mac remember that closing any open program windows does not shutdown the software.
    To do that you need to either have the program foremost and hold down a command key (the ones with the Apple logo on them) and with command help down press Q, or alternatively click the program's name on the menu bar (next to the Apple logo in the top left corner of the screen) and select Quit from the bottom of the menu that pops up.
    Restarting both the scanner and the software at the same time will eliminate any simple, non-physical problems as you've already reset the device's chip-set.
    If this doesn't help then it is most likely that that something was damaged when you forcibly removed the negative carriage, the mechanical components of this device are minimal but small and include a few springs so you're going to need to decide if you want to get your hands dirty or not.
    Alternatively you can have it repaired but as Konica Minolta no longer service there own image related products they're referring customers to Sony from this page ca.konicaminolta.com/support/contact/sonylist/index.html
SOURCE:
How do I turn old negatives that won't fit the holder into photos? They are 3.5" x 2" or 82 x 57 mm for you kids!
That model does not support scanning those size negatives - only 35mm strips or slides.
Nov 19, 2009 | HP Photosmart 3210 Printer
Inability to copy film to pictures
When you were scanning, did you set the scan selection to scan negatives ?
Jan 20, 2008 | Canon CanoScan 8600F Flatbed Scanner
Loading negative film in holder.
The button under the top door is for ejecting the film strip. To load negatives you just insert them until the machine recognizes them and then it will automatically load them.
Apr 12, 2009 | Epson Perfection 3590 Photo Flatbed...
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
White lines in negative scans
could be the component scanner inside of the minolta , it will need to be tested to determine if the scanners components or a wire strip is causing the problem or the component scanner its self , it sounds like a section of it is out so it will not see anything ------ ---------- in that section
Oct 08, 2008 | Elite Minolta Dimage Scan 5400 Scanner
Scanned negatives are not sharp.
One workaround is this: use the holder for the negatives as a guide but not as a holder as such.
To do this, place the film negative directly on the glass plate, then put the negative holder (completely assembled) on top of it; align the film and the holder so that the frames on the filmstrip line up with the marks on the holder correctly.
Now, close the lid and follow the normal procedure for scanning negatives. They're noticeably sharper this way, suggesting that the scanner's focus is set for items placed directly on the glass plate. I have no idea why focus isn't adjusted correctly for negatives, which site a millimetre or two above the glass.
Aug 27, 2008 | Canon MP970 Photo All-In-One InkJet...
Mac OS X Leopard & Dimage Scan Elite II
Forget about the Minolta software. It's buggy at best with OS X. Use VueScan instead. A free trial is available so you can test it before you commit to buying it.
http://www.hamrick.com
Aug 25, 2008 | Konica Minolta Konica/Minolta Dimage Dual...
Konica Minolta Dimage Scan Dual IV won't scan slides properly
Forget about the Minolta software. It's buggy at best. Use VueScan instead. A free trial is available so you can test it before you commit to buying it. Available for Windows including Vista.
Jul 08, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Film holder problem
try this
Turn on the scaner (diode is blinking), then run aplication DS Dual3
After start application you sould hear the transport mechanism test.
The green diode should light permanently (important).
Push deeper the holder.
Jarek
Jan 29, 2008 | Minolta Dimage Scan Dual III Film Scanner
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
Konica Minolta Konica/Minolta Dimage Dual IV Film Scanner Logo
227 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
