Question about Boss Riot 1500D Car Audio Amplifier
BOSS RT1500D PROBLEM
Well when i took my amp out of my car about 5 months ago because my sub was sounding bad. The amp was working at the time i unhooked it. Ive reinstalled everything and can not get power to the amp. I hooked it up to my roomates wires in his trunk and still no power. I opened it up, and go figure a wire is loose inside. It is the ground wire and the solder on it broke and i cant tell where it is supposed to go, does anyone have a picture of the internals of this amp?
  • 752 Answers
Can you post a pic of the wire and surrounding area?
Posted on Sep 22, 2007
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
What would be the best way to wire 2 1800w 4 ohm boss compact speakers to the boss cx950 amp
As the amp cannot support a 2ohm load you have to hook each sub up to one channel on the sub and you can't run them in bridged mode.
Mar 09, 2012 | BOSS AUDIO SYSTEMS CX950 Car Amp
I have a boss s120.5a 12" sub with 5 channel 3000
Check the power pack and the fuse to make sure the are working but if the are not okay then take the car audio amplifier to audio mechanic.
Jan 22, 2011 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
Boss BA-2900 car amp doesnt produce any sound
i have come across a similar problem before. if you are using the ceramic (glass, clear) fuses the solder in the end caps sometimes melts. you will not see the fuse blown, but the fuse may still be bad. try a new fuse to see if that works. also make sure no single stray strands of wire from a positive or negative wire are touching on the terminals on the amp. i hope this helps. ill keep thinking of other things in the meantime
Jan 05, 2009 | Boss Car Audio & Video
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
Amp does not power on, flickers when cable disconnected.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 05, 2007 | Car Audio & Video
Boss Riot 1500D Car Audio Amplifier Logo
80 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
