Question about Uniden BC60XLT-1 (30 Channels) 2-Way Radio
L/O wont turn off
Hi. my scanner wont work because all the channels are locked out. i press the L/O button and it wont turn off. Is there a reset or a way to easily fix this? Thanks
How do I unlock
Posted on Sep 03, 2007
    Problem Solver:
  • 20 Answers
Do a search for the manual online..... there are tons of sites out there with scanner info.
Posted on Aug 24, 2007
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
My scanner was woking fine untill i hit a button by mistake and now it wont scan through the channels ... i dont know what button i pushed!
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.try this the channels could be locked
Jan 22, 2011 | Uniden BC898T Base Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
All channels are locked
The above reset does work. I took it to Radio Shack and the guy reloaded my freq.
Sorry about the false report.
Apr 20, 2008 | Radio Shack Pro-97 Handheld Scanner
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Locked out!
press and hols down the "LOCK" for three seconds
Aug 16, 2007 | Radio Shack Pro-82 Scanner
Uniden BC60XLT-1 (30 Channels) 2-Way Radio Logo
134 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
