Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi WS-65869 65 in. Power Light
We have a Mitshbishi WS-65869 rear projection TV that is about 4 years old. When we go to turn on the TV, the power light turns on for a second, then just shuts off. There is no picture on the TV. We have tried using the reset button as well as unplugging the TV, and that does not solve the problem. Thank you so much for your help. i tried your solution - i was trying to locate the fuses. can you please advise me where the fuses are located. on the main board? or do they plug into the main board? or what other board, ????? etc.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Posted on Aug 24, 2007
SOURCE:
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv is not working will not turn on ,the green light is blinking, this happened after a power outage
I have a 26 year old TV... It is a RCA color track 2000. it will not turn on. Can anyone help?????
Apr 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
65 INCH-MITSUBISHI TV WS-65908 WILL NOT POWER UP
same problem with mine.. i usaually hit the reset button if it continues you need to get it service. when i called for service i stik had warranty and they replaced a capaciter.. it would of cost atleast $500. GOOD LUCK
Jan 26, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Aug 31, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Help on Mitsubishi WS- 65513 65 in.
Look around online and find that this is a huge problem with Mitsubishi rear projection tv's. It is the board that needs replacing at $1100. My tv is 3 years old and already a big paperweight. Blinking green light of death.
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitshibishi 65 " HDTV
Check 5A micro fuses F9A04 and F9A05 - If one or both are open,change the single convergence IC part# STK393-110.
Aug 22, 2007 | Mitsubishi WS-65869 65" Rear Projection...
TV will not turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Apr 09, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Problem with WS-65869
One of the 3 CRT's being bad is a possibility but more than that at one time no. If the picture doesn't come on at all or any menus showing up the most likely you have a power supply or high voltage issue. Have a technician look at it for the best diagnosis.
Apr 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
