Question about Technics SA-DX940
Erratic volume on Technics SU-X911 amplifier (Class A)
Hello, was wondering if someone could advise on this problem ... Background: My midi Amp (SU-X911) is part of a Technics system (CD player, Tuner, Cassette Deck, Equalizer). The system was bought sometime in the late 80's (yes it's old). Problem: Amp volume (controlled by electronic dial) DANGEROUSLY ERRATIC - suddenly silent for 2-3 seconds, before jumping to almost max! Adjustment to volume control brings it back to normal volume. During the silent and max jump, the volume level display (eg. "-44dB") does not change. Consequences: My precious speakers risk being blown up! Remedy attempts so far: Following advice from an electrician colleague, I've pulled apart the amp, pulled out the volume control potentiometer and spray cleaned it (with electronic spray). I must say the amp was generally very very clean inside. Success? - No, problem returned after one day of amp operation. Other Notes: My colleague now suggests it could be the amp itself playing up (ie. not the volume pot). I listened to a whole CD (45mins) last night, and did not encounter the problem - interesting to see if the problem occurs using headphones as well as the speakers themselves. Any ideas anyone? Would greatly appreciate advice - perhaps there's one bit of the amp I need to look at / replace. Thanks!!!
  • babiuk Aug 30, 2008
    Hello, I´ve got the same problem in the same amp, it sounded ok till one day it begun to mute itself randomly and jump to high volume in the next minutes.
    A month ago the problem turned into playing normal for a few minutes and after that I just got silence.
    And nowdays it doesn´t sound anymore.
    I tried to use the headphones... but nothing.
    Please tell something about if you´ve got solved it.
    Thanks
    and excuse my bad english.
    Bye!
I have a technics su x911 linked to ars x911 and a sl pj26a and a st x 933l tuner and turntable, they are all linked to each other as is typical however, I can turn the amp on,the red light shows on and everything else will work but not the amp.there is no led display and no vulume control.
the set has not been used for many years but has been kept clean and dry.
do they have to be connected in a certain order, the remote control doesnt seem to make any difference.
Posted on Aug 19, 2009
  • Audio Service Clinic Jan 03, 2015
    Without seeing the schematic, both the volume control and illumination, may be tied togther in the power supply. This is too old a unit to use a Rotary Encodre(new style volume cotrol), so that's not the issue. Your amplifiers are not bad; it's what's controlong them that is at issue. For more information, or to inquire about haing your Technics repaired, please visit my website at audioserviceclinic.com. You may contact me there.
  • 71 Answers
Its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Posted on Dec 08, 2008
    Not every issue in the world is a bad capacitor. These bad caps entered the marketplace in about 1999-2000. If they are not bad, you are wasting your time and money replacing them, just to turn it back on and have the same issue. Measure twice; replace once.
    New Friend:
My problem is the volume contorlb they use MN4030B and another MN which has blast on the circuit board.i will like to know number to replace it.This is my email [email protected] you can get me on face book jerrygadogbe.
Posted on Sep 07, 2011
    This IC, and it's complement, MN4070B/S are logic ICs, and mostly, have nothing to do with a volume control control issue.
SOURCE:
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Good day i have a Technics amplifier SU-X320. Problem is it powers up up there is no sound. Checked all basic fault finding, suspect it is the volume IC.
"Volume IC" do you mean an IC that is a pre-amp and controls the volume and things like tone? Or do you mean the main power amp IC, which will be on the big heat sink?
If you amp uses the latter and not individual separate devices for the power amp, suspect that over the other IC. But if the amp has separate power amps for both channels, replace the IC.
Oct 09, 2013 | Technics Audio Players & Recorders
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Su-v55a technics amp cuts off when volume up to 2. 1
poor solder connections to the volume pot It needs to be resoldered
Aug 19, 2010 | Technics SUV500 2-Channel Amplifier
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Lost left stereo channel from amp. All speakers / wiring ok Technics SU-V6 amplifier. Wondering which component is most likely problem so I can cannibalise another amp.
If at full volume with the balance cutting out the right channel you can hear some music on the left (very weak), then the pre-amp is working and it's the power amp that's gone. Vice-versa if you can't anything, but say hum.
If it is the power amp check out the devices on the heat sink.
Check too for broken or burnt parts too!
Jan 21, 2010 | Audio Players & Recorders
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: [email protected]
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
About amplifier specification
sounds like you need a service or users manual...check their website,to find one
May 25, 2008 | Computers & Internet
Technics SA-DX940 Logo
2,601 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
