Question about Pioneer VSX-1016 Receiver
No Video Using HDMI connection, I have a Direct TV HD-DVR connected to the receiver and the receiver connected to my plasma TV. I cannot get a video on my TV. If I run the HDMI cable from the DVR to the TV it works fine.
  • mitsiman Dec 11, 2007
    Exactly same problem , just get blue screen . Tv is a Samsung LE40 . Works fine from dvd to tv , just when go to reciever . The anynet ( samsung function ) works fine so it knows a connection is there . Come on Guys help us out .
  • Anonymous Mar 25, 2014
    No sound when hdmi plugged in DVR section
Have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Posted on Dec 13, 2007
How to connect two TVS to one HD DVR
You will have to either get a hdmi splitter and a wireless hdmi sender or a wireless component video sender which the hdmi splitter runs about $50 and the wireless sender is about $200
Feb 21, 2013 | Directv R22 Hd Or Sd Dvr Direct Tv R22-100
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Nov 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Don't want to use receiver to turn Plasma on via Verizon DVR
You can not have a signal from cable/satelite TV when reciever is OFF.The only way is reconnect by using defferent setup configuration to illiminate the receiver.In that case you well see just regular Tv program but you should connect antena to your TV.
Apr 17, 2009 | Onkyo TX-SR705 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Pioneer VSX-1016 Receiver Logo
295 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
