Question about Hotpoint  21.8 Cu. Ft. Top-Freezer Refrigerator
Would not shut off
I bought this refrigerator in 2004 and after less then 2 years it would not run properly. It was on all the time and nothing was getting cold.
  • 291 Answers
Check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Posted on Sep 03, 2007
SOURCE:
What causes the vehicle to shut off as if it runs out gas?
It take 3 things to make a engine work and run properly.
1. Fuel
2.Fire or spark
3. Air
You need to check each of these and see which ones lacking.
Also these 3 need to be in proper timing.
The most common problem I see is a bad fuel pump, since most are electric these days and are in the fuel tank. Less often I find a bad coil pack, which creates the spark. The last is check your filters, both air and fuel filters. One diesel models I see dirty oil filters causing the engine to run poorly or shut off as the injectors run off oil pressure.
Aug 24, 2014 | 2004 Ford Expedition
GE Monogram built refrigerator defrost problem
What to do? It has been in service more or less for 12 years, way past time to replace.
Mar 03, 2017 | Refrigerators
Battery light on my 2004 chevy trailblazer. It lasted a day then all the ABS breake light came on the the battery drained. The truck shut off. What could this be. I bought a brnad new battery 2 years ago.
The battery light comes on when there is an issue with the charging system. Most likley you have a bad alternator. With the engine running you should see a min. of 13.5 volts at the battery and better yet 14+ volts. If you have 12.5 or less than the alternator is not charging.
Once the vehicle is started the battery is no longer in play. The alternator is what keeps the power supply to the vehicle and recharges the battery for the next time you want to start the vehicle. Once battery voltage drops below 9 volts or so systems start to shut down. Eventually the battery will drain enough that the engine management system can no longer function and the vehicle will stall.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 30, 2011 | 2004 Chevrolet TrailBlazer
Refrigerator runs constantly -- shuts off 3X a day for about 30 mins. each time -- bottom freezer model BX 21VW -- bought in yr. 2000 --- Serial # 0008208852
Refrigerators shut off and on time depends on the outside temperature, and how often you open it according the temperature setting. Lower temperature setting would yield less turn off time and higher temp seting would yiel less running time and vise versa.
Jun 01, 2011 | Amana Refrigerators
I shut down my laptop and it said shutting down and turned off. Now when I try to turn it on it won't come on .3 little lights blink in front 3 times and does nothing. nothing shows on the screen and it...
try these 3 steps enable for you to resolve your problem:
1. re-install OS
if that would not work try the next step
2. detach the power cable that is connected to the mother and plug it back in if that would not work try the lst step
3. check for the warranty and have the unit replced by the manufacturer
Sep 11, 2010 | Computers & Internet
3 year old VUAR141 cools but only gets down to 16C at coldest setting(spec is 4 to 14 C)Compressor and cooling fan only run for approx 3 minutes then shut off for 20 minutes or more before restarting....
Those symptoms you describe indicate a compressor that is "short cycling", if it is indeed starting and running for those 3 minutes. Is the evaporator cold for those three minutes as well? Many times people think its running, then shutting off, when in fact it is only trying to start. Without proper tools you cant test compressor, but it might be worth finding out from a repair service if its the compressor or the compressor starter, the latter of which is much much less expensive.
Assuming the other motors on the cabinet are running, you've narrowed your problem down to 2 things, the compressor itself, or the start device has failed. Without the proper tools you wont be able to test the compressor first. My advice, go to repair clinic . com, see what a starter will cost you, if you can find a repairman to check your compressor for cheaper than what it costs to buy starter, well there you go. Either way, if its the compressor thats bad, you wont want to spend the money to replace, unless you have a built in worth several thousand, or physical constraints of kitchen prevent you from buying new fridge.
Visit: www.FixMyFridge.net for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
Mar 22, 2010 | Viking Professional Series VUAR141
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
2004 Maxima Turns Off while driving and trans. probs follow
Mine did the same but at 120 km but i just pulled over put it in park and restarted it and there has been no problems since, this was 2 months ago
Jul 06, 2009 | 2004 Nissan Maxima
GE Side by Side not getting Cold
First things first - check to see if the compressor, big motor on bottom is running. That is the unit that is responsible for cooling. If not running check the start cap/relay.
Jun 28, 2017 | Refrigerators
Leveling refrigerator
In a Home the recommended level (front higher to back lower) is 1/4" (Right to Left - level)
Never less than in order to allow door to shut own their own, but there is nothing wrong with having a perfect level refrig if everyone closes the doors properly which they won't. A refrigerator requires to be reasonable leveled to avoid compressor fatigue. In a Motorhome people can't always find level ground, so it quite frequent that their refrigerator burns up when running. From that experience I'd say I would level any fridge which is over 1/2 inch off.
Nov 02, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
Hotpoint  21.8 Cu. Ft. Top-Freezer Refrigerator Logo
47 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
