FixYa.com
Tags:
U.S. Robotics USR8001 Router
ICMP: type 3 code 4 Errors
posted by Davro on Aug 24, 2007
Problems communicating through the router. Lots of ICMP type 3 code 4 errors in the log. Accessing a web site will be mostly ok but then a click will cause an infinite "waiting for ..."
Comment by Davro, posted on Aug 25, 2007
Hi there. In response to the last post, I've tried reset and the support page at USR. The firmware upgrade is v1.1 which is already installed in the router. The ICMP 3 code 4 means MTU too large and is probably part of a MTU discovery sequence but something get's lost somewhere. I have links on web pages that I click on that start displaying data but never finish. There are other web sites that get stuck in a logon process. If I switch to a wireless router I also have, everything works correctly. Thanks for trying. Davro.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
hughv
Rank:Wiz Wiz
Rating: 82%, 233 votes
The USR support page is here:
http://www.usr.com/support/s-main-menu.a...
Use the search engine at the bottom of the page to find your model.
I see a firmware update listed, but I would start with a complete re-set and re-configure. There are just too many variables to give you an exact solution without access to the router.
Rating Locked! (?) Davro has rated this solution as Thanks for Trying
Solution #2
jed09
Rank:Guide Guide
Rating: 74%, 8 votes
Maybe its the configuration of the router. Just try to configure the router, check its cables and check also the bandwidth.
Can you Help with these Routers problems?
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
