Question about Philips Magnavox 27MS343S 27" TV
2 Problems The picture is bigger than the screen size so i lose some picture on all sides of the TV. My second problem is when i hook up my DVD player up to the TV the sound still works but no picture will show... please help
  • nossam Dec 23, 2007
    I cannot see all the undertitles. The titles looks to wide on the edge of the screen
    New Friend:
Resolder the printed board at the suspected area of your tv.
Posted on May 07, 2013
    Problem Solver:
  • 5 Answers
1st problem-reduce the supply voltage on the power supply to the recommended 95v.if prob does not clear change suspect capacitors around the line output transformer. 2nd problem-check;continuity of av-cables ;dry joints on av inlet sockets of the tv card.
Posted on Aug 24, 2007
My panasonic dvd player will not show the whole screen when in dvd mode
Hi
First make sure your Panasonic has 16:9 TV mode selected within its menu. Then try chainging the picture size on your TV. You didn't say what model TV you have. On my Samsung you would press the menu key then select picture, scroll down and select picture size. From hear you can select 16:9, wide zoom, zoom, 4:3. Try looking for picture size and selecting 16:9 on your TV.
Jun 03, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
No matter which picture size I select, I cannot ever seem to get the picture from the DVD to fit the screen. For instance, I am watching a DVD right now that is in wide screen, and when in...
U tries used the DVD player remote to fix this problems,could be the DVD movie?Have the same problems,with the regular tv incomming broadcasting signal?Yes,than the tv Tuner signal board is the problems and the causes it dying and shorted.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 27, 2011 | Sansui SLED2280 22 in. LCD TV
I am hooking a dvd player to our new flat screen....I hear sound but no picture
at the side of the flat screen there is tv in so check the cord and make sure it goes directly to tv in ok.
May 23, 2010 | Sony DVP-SR200P DVD Player
Samsung tx-p2734 TV Issues: Wavy lines on SIDE of tube...
For the buzzing noise try tipping tv jently forward and jently placing back.
May 07, 2009 | Samsung TXP2734 27" TV
The problem with my NEC 68T90 TV is that the screen resolution is not correct. At 4:3 ratio, I can't see the sides of any video or TV program that I'm watching. Is there a problem with the hardware?
Try the aspect button on your remote, or if you have this hooked up to a cable or satellite converter, there are screen resolution preferences, you can change the screen resolution here, go the the menu portion and look for video/audio field
May 07, 2008 | Televison & Video
PORTABLE DVE PLAYER MODEL PDV-705
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up. This button is about the size of a pin on most DVD Players4.gif, and is located very close to the screen on either side.
Jan 10, 2008 | Durabrand PDV-705 Portable DVD Player
Aquos set up
wild shipping my sharp aquos 42 inch it get a crack in the screen can i buy just a screen for it and what's the cost for it
Dec 15, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
