Question about Compaq Rechargeable Wireless Optical Mouse 2295175
Can not use the mouse for my computer
I instal the systeme in my computer,but I can not use it. That's means the mouse can not connect to the computer. Please can you help me with that. Thank you!!! My best regard
  • 42 Answers
Hi Have you check the batteries work and that the drivers have all been loaded if this has been done the all i can sagest is that you return it back for a replacement
Posted on Aug 24, 2007
Hype optical mouse model no. HY-7005-WMA 2.4GHz isn't working properly, wont connect to any device. How do I get the adapter signal to read on my laptop?
So you're saying you've tried connecting to other devices to no avail?
Might be worth reading the direction carefully. Sometimes there's a reset/rescan button(small) on the mouse that needs to be engaged after everything is plugged in.
Oct 31, 2014 | Hype 2.4GHz Wireless Optical Mouse -Blue
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
How do I use mouse instead of touchscreen on Samsung laptop
Do you have a mouse connected by cable or a USB dongle? If so, then your computer's Plug and Plug (PnP) capability to detect, install and activate peripheral device drivers will have recognize the mouse and made it accessible to you. If the mouse in not usable, look in Start, Computer, System Properties, Device Manager, Mice (etc.). If you have a Yellow Triangle, click on the mouse then the Driver Tab to Update the driver. This should solve you problem. You may have to Restart to gain access. If that doesn't work. Unplug the mouse connection, Restart the computer, then plug the mouse connection in again. Watch to see if PnP detects the connection and installs it.
Sep 20, 2014 | Samsung Computers & Internet
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Mouse lights up, will not drive cursor
Hi telsmith42,
Please check if the mouse's driver has been installed properly , a good idea would be to check in control panel or system properties --> in the hardware tab --> in the device manager.
In the mouse and other printing devices section , right click the mouse that you see as active and go in properties , it should say , the device is working properly.
When you get this message it means that there is no problem of connectivity between mouse and the computer.
Now if you have a cross at the mouse and printing devices section instead of a mouse , then that means there is no connectivity established yet , which could be as a result of drivers not being installed.
If you see this problem you need to install the drivers that came along with your mouse probably in a compact disc.
If still the problem does not get resolved you should replace the mouse if it's under warranty period which is a case of manufacturer's defect.
Hope this helps ...:)
May 10, 2011 | Laser Cellink OPMP-2401 Mouse
I am plugging the stick into my office laptop. There doesn't seem to be a connection with the stick and the mouse.
First off make sure you have fresh batteries in the mouse. If the batteries are missing or weak then that would cause the no connection between the mouse and the usb stick.
After you check the mouse out for fresh batteries, then go ahead and plug the usb stick into your laptop. At this point you should hear a sound and windows should install the drivers for that mouse, if it doesn't then the next thing would be to try another computer or laptop that has working usb ports and try to connect the usb stick on another computer.
If it works then that means there is an issue with the usb ports on your office laptop. If the mouse still doesn't work then that means the usb stick is bad and you would need to buy a new mouse.
Sep 30, 2010 | Wenger DAYTONA II Mouse
Mouse not responding
Clean the PC Mouse
1. Unplug the mouse, turn it over, then twist the retaining ring counter clockwise to remove it. Remove the trackball inside the mouse.
2.Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in alcohol. Replace the trackball then secure it with the retaining ring.
3.Clean the outside of the mouse with rubbing alcohol and a cotton ball. Use a small amount on one area at a time. For an optical mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Fix PC Mouse Problems
1.Plug the mouse back in. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins, then carefully plug it in making sure the connection is secure. Reboot the computer, and then test the mouse.
2.Connect the mouse to another computer. After the mouse is connected to a different computer, reboot the system, and then test the mouse. If your mouse works on another computer, the problem is most likely with your PC or operating system
3.Check for device conflicts. When you install another device on your computer it can sometimes cause conflicts with a PC mouse. Remove any new hardware and drivers you may have installed then reboot the computer.
4.Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Driver" tab then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse then reboot the PC. Reboot the system again, plug the mouse back in, then allow Windows to reinstall the drivers if prompted.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 19, 2010 | Computers & Internet
I need driver for 3M EM500GPS 3 Buttons USB Optical Ergonomic Mouse
Should be plug and play for Vista, XP, and later.
Manual and Information here.
Page GB-12 of manual
Mouse Not Detected
Computer ports are improperly
set up (for example, are disabled).
Conflicts among other devices connected.
Installed on an incompatible operating system.
Check with your computer system dealer or
manufacturer if you need help.
Resolve any conflicts among devices connected to
your computer.
Compatible operating systems for the 3M
Ergonomic Mouse EM550 are listed on page 2.
Nov 17, 2009 | 3M em500gps Mouse
Had laptop repaired,did system restore but gone
Try to get a normal mouse in a shop, cheap and with no install of drivers or use your friends, then try to run chkdsk from the computer with the new mouse, normally you find it here :
start- my computer- c:- right click and then choose properties (the last one on the menu), then select the second tab and then select the first choose (check drives for errors) check all the possibilities and press ok to restart the computer, and see id it is gone now after it has run.
IF NOT then you need to reinstall your mouse driver, you can try in the first place to reinstall it above the old installed files with the provided cd rom. If it not works you need to remove the installation for the mouse, you can find it in "add and remove" programs in "control panel" and the reboot the computer and then reinstall the driver
If it is a plug and play mouse (that means you do not have any drivers installation, widows did install it by itself), then you need to plug the mouse in go to, start- control panel- administration-computeradministration- then choose the computer icon ( I do not know the name in English, because I use the danish version), but there you can see all the hardware on the computer, there you choose the mouse and find your mouse and then right click on the mouse and choose remove. after that you have to reboot the computer and then connect it again and then it should work
IF the above is not working I suggest to reinstall the operating system Windows, but before that then make sure to save all your documents and pictures etc, because it delete all the content
Hope that helps
Have a nice time over there
Please rate my answer
Oct 07, 2009 | Computers & Internet
Mouse won't connect
Dear, as i can understand, your mouse is connected properly but the problem is in sending signals to the computer to responed the actions of mouse. There may two reasons.
1. There may some kind of problem in the mouse, thats why, it is not sending the proper signals to the computer.
2. There may be a worm or virus that is causing disturbance with the mouse driver.
You need to check another mouse with your system or this mouse with another system to make sure about the real problem. If the mouse is workind proerly on the other computer then need to fix you computer by installing the driver again or by scanning your computer for worms and viruses using anti virus or need to install the operating system again.
Best regards.
May 25, 2009 | Logitech 9311570403 Mouse
Computers & Internet Logo
94 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
