Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Only red bulb working
I have a WS-55315 that is about four years old. After a storm a few weeks ago, only RED works. When I take off the back, I can see that there is not even a dim glow on either the green or blue bulbs. Where to start?
Tried restoring to factory settings? Only blue was working for me and it helped *shruggs*. You can try... On the remote, press MENU then 1 2 3. Hit Enter. And it's restored to factory settings :]
Posted on Sep 16, 2007
I have a Mitsubishi WS-55315 55-inch tv that suddenly without warning the picture seems to have lost all red color. The picture seems clear but it is mostly green in color. The problem is intermittant...
Check the componet cables if you are using them for video from the cable box, the red may of came loose.Also you could have intermittent connection the video processor IC or as we techs call it the jungle IC. It is responsible for producing all the small singals used by the set.Tapping with the handle of a screwdriver on the signal board may lead you
Jul 21, 2011 | Mitsubishi WS-55315 55" Rear Projection...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Red projector problem?
Most likely its the red drive transistor on the Red CRT pcb which is defective, or it could be as simple as a solder joint issue on the Red CRT pcb.
Jul 15, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Philips 42PF9945 on/off switch problems
Hi huttleywoof,
I've had the same problem 1 week ago. Bought new wirewound ceramic resistors (5w 6.8 ohms) and replaced the old ones.... It helped to majority of people who had the same problem, but mine has now some other issues with appearing diffrent colors on the screen which are not supposed to be there :) Like all goes blask with few red pixels or green :-) Having fun now and can;t find service manuals for this TV :(
Feb 16, 2008 | Televison & Video
WS-55315 Red Gun Slow to come on
You could have a bad transistor for the red gun on the neck board or possibly a cracked solder joint on the transistor. The red gun may need to be 'cleaned' by a rejuvination process. The guns can get a buildup on them after time that needs to be burned off to bring it back to life. In some cases, if the coating on the gun is very thin it can be burned completely off during a rejuv. process leaving it totally unusable. It is possible to use a charged capacitor to 'zap' the guns to attempt a rejuv., but it may need more than what a capacitor can give it.
Dec 19, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
WS-55315 with only red bulb
It seems that you donot have the 200+ V line for the GREEN,BLUE. This line is the same as the read line, check connectors located on crt boards make sure they did not come apart. Also you can:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Aug 24, 2007 | Mitsubishi WS-55513 55" Rear Projection...
MITSUBISHI WS-65908 red crt going off and on
You don't have enough soder on the STK392-570 unit ! I had to re-soder mine and is OK now
Aug 02, 2007 | Mitsubishi WS-65908 TV
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
