Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Hitachi 42EDT41 Had a major surge hit my house. Now my component input does not work, and my TV shuts off randomly. I also noticed white and blue pixels going on and off all over the TV while watching movies and playing games. Does anyone else have this problem as far as the pixels are concerned? Is this a serious issue? Should I start looking for a new set?
    Scholar:
  • 87 Answers
There may be a software glitch. Call Hitachi customer service and ask if your model needs a firmware update to get rid of the sparkles.They also have a website WWW.hitachiserviceusa.com
Posted on Mar 08, 2008
SOURCE:
Hitachi le55a6r9a sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Jan 23, 2017 | Hitachi Televison & Video
Y Component Cable Related - Internal Static Noise
It sounds like one of those cables has a defective ground. The static noise you are experiencing is cause by the cables not inside the TV. Try using different cables to isolate the problem and get new ones.
Good Luck.
Feb 17, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
What cables go from my 55 inch hitachi tv to connect on the back of the dvd player . I have two monster cables red and blue together and three cables red blue and green together.
I have never herd of a red and blue combo but, The three, red, blue, and green are "component" cables. Hopefully your DVD player has a red, blue, adn green component out, not to be confused with red composite out. Composite cables are yellow, red and white, and, your tv has componenet in. The component cable will give you the best video quality. When installing make sure they are inserted all the way but twisting and wiggling or you will have a bluish, grenish, etc. picture. The composite cables give you the video only, so you will have to provide the audio. Audio can be achived using composite red and white or digital optical.If you second monster cable is red and white you can probably use those To go from "audio" red and white out on DVD to audio in red and white on tv. You must use the same audio input that corresponds to you video input.
Apr 09, 2011 | LG BD550 Blu-Ray Player
No this didnt help at all, my samsung tv still turns out black and white, im not using a HDM1 cable im just trying to get the normal tv to work, i have noticed the tv only has the green, blue, and red...
As long as you can see that those ports on the back of you TV say input and not output then your compsit color code is White=audio, Red=audio, Yellow=video. It should work the green, blue, and red is just another type of component use. Good Luck!
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
I have a hitachi tv model 42edt41 year 2004,2005
I have the same tv and had the same problem. I found a posting that stated to re-solder a connection on the cable for the "y" boards. I used this and my tv is perfect now. The part that needs to be re-soldered is the ribbon cables at the bottom of the tv that go from the boards straight to the screen. On the inside of this ribbon cables there are 4 small components that have "100" on them. On each end of each of these pieces, re-solder them. Since I had my tv completely apart I re-soldered all of them across the bottom. No problems now!
Oct 05, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
My hitachi 42edt41 42in picture flickers
First. Try using a surge protector.
Could also try purchase a HDMI cable that is compatible with 100Hz,
Possible problems:
backlight inverter wearing out
Very Common In The Newer Tv Sets
Tv's have a chemical/molocules called phosphors that can be deentergized when a tv is left on for a long period of time. Not a serious problem but still annoying
Jan 16, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Attaching a surround sound to a Hitachi 60CX29B
the red green and blue are component video
to get the surround sound to work the red and white audio outputs from the tv go to the audio inputs on the reciever , and to get the digital surround sound the optical also has to be hooked up
Nov 06, 2008 | Hitachi 60CX29B TV
Hitachi 42 Plasma TV
Do the lines move at all, or are they static? Someone else had a similar problem, and a fix that might work for you was posted at:
http://www.fixya.com/support/t293678-plasmaa_tv_not_going
Aug 21, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42"
Its impossible to say without knowing more than that. If the TV does not detect any signal on whichever input (other than CATV) your on, it will power down. Make sure you are getting an input signal and make sure you are on the right input on the screen.
More info on your problem and i could probably help you better!
Jan 11, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
